How to Use CAD-CAM to Resurface a Spoil Board
Posted December 21, 2021 3:39 pm   Published by    BobCAD-CAM ">
The purpose of the facing operation is to clean up the top of the stock material. Exactly how this operation is performed is dictated by the settings of the operation. Using the settings can define a facing operation to resurface a spoil board for your router.
When facing a spoil board in BobCAD, the user will first need to set up the stock, machine setup, and toolpath before sending the code to the machine. This document will provide a brief tutorial on how you might go about creating and posting a CAM Job using a facing operation for the spoil board.
In the Create 2D tab, select the Rectangle option. For the length and width of the rectangle, input the values of the spoil board that is being faced. This example will use a 4’ x 8’ spoil board or 48ā€ x 96ā€ (Length x Width). In the Base Point section, select the bottom left corner option to place the geometry in the upper right-hand quadrant. Click OK, then Cancel.
Right-click on CAM Defaults in the CAM Tree and select New Job. For the ā€œJob Typeā€, select Milling and choose your machine from the drop-down if it’s not already there by default. Then, click Stock Wizard. We can skip the Workpiece page since we do not have a solid model of the workpiece. We can leave the stock rectangular and a bounding box around the stock we previously drew.
Right-click on the Machine Setup – 1 in the CAM Tree and select Mill Facing. On the Geometry Selection page, no action is needed. The software will use the info from the Stock Wizard that we setup in the previous steps. Click Next. On the Feature page (shown in the image below), keep the Top of Feature set to the default as this value is automatically set to 0.0000. This is because our top of the stock is in relation to the Machine Origin. Adjust the Depth to the depth of the cut from the top of the spoil board. In this example, we will leave this value set to 0.1000. Click Next until you get to the Tool Page (Rough).
Setting the Total Depth of the Facing Operation
On the Tool Page (Rough) (shown in the image below), choose the tool that will be used in the facing feature. In this example, a 2 Diam Face Endmill will be used.
Note: To access this tool from the Tool Library, click on Tool Crib > Add From Tool Library. Sort by Diameter by clicking on the Diameter column at the top and find the default tool called, “2 Face MILL”. Select it and click OK. Then, click OK again in the Tool Crib page. Click Next.
Setting the Correct Facing Tool
On the Patterns page, set the Stepover (Distance between each pass) for the feature. The default is set to 50%. For this example, set the Stepover to 75%. This would set the Stepover distance to 1.5 inches. We will leave the other pages to the default settings and click Compute at the bottom right.
Computed Mill Facing Toolpath
Note: Since this toolpath is offset for the tool radius at the end of each pass, this could go past the machine limits if the limit is exactly 4’ x 8’. We can resolve this by editing the feature and going to the Patterns page. Change the pattern to On Workpiece:
On Workpiece – keeps the toolpath contained within the bounds of the part and enables the Distance (% of Tool Diameter) box.
On Workpiece
Distance (% of Tool Diameter) – 50 percent of the tool diameter will cancel out the offset and contain the toolpath to exactly 4’ x 8’ across the spoil board. Compute the feature again to update the toolpath.
If you are happy with the results and want to send the G-Code to your machine, Right-click in the Posting window and click Save As to save to a flash-drive. If you are in the NC Editor, go to File > Save > Save As to save to a flash-drive or go to the Tools tab and click Start DNC Transfer to send the g-code through a RS232 cable.
This information is also found in our Knowledgebase for common questions about various functions in BobCAD-CAM. Our Knowledgebase documentation can be found here: https://bobcadsupport.com
forum.bobcad.com
