Tech Tuesday: 4 Axis Milling – Project Curves
Posted November 30, 2021 3:45 pm   Published by    BobCAD-CAM ">
In this example, we can see a part above a fixture where the radius is not continuous around the geometry. We would not be able to use a wrapping group since the tool will have to follow around the rotary axis in more of an ellipse shape, continually changing the tilt angle around the rotary axis. We will need to use one of the surface-based toolpaths like Project Curves, which is included in the 4X Mill Pro package.
4 Axis Milling Project Curves
The Project Curves feature is used to create projected toolpaths using either a user-defined geometry curve, offsets of that curve, a radial pattern, or a spiral pattern. When selecting curve geometry directly from a surface, the projected toolpath is identical to the original. When the curve geometry is above the surface there are multiple possible results depending on the scenario and parameter selections. This pattern can be used to create engravings as well as spiral or radial finishing patterns for complete surfaces. In this case, we will be creating a radial finishing pass around this part. To begin, we will right-click on Machine Setup – 1 in the CAM Tree of an existing milling job and select Mill Multiaxis. We then select the Project Curves operation type under the surface-based toolpath operations.
Toolpath Type
After selecting this operation, we can skip to the tool page to define the specific tool we are using. In this example, we selected a flat endmill that will follow along the sides of the part in gray and follow right above the top surface of the fixture in orange. After the tool page, the next page allows you to select the geometry to define the toolpath. The first selection, Projection Curves, will be the top edges of the part in gray. As a side note, the Projection Curves could be wireframe from a solid model. It can even be geometry that has not yet been projected to a curved surface. The Project Curves operation will project the toolpath to the surface automatically.
This brings us to the Drive Surface selection. This is the surface the toolpath will be projected to. A couple useful options below this geometry selection include:
  • Drive Surfaces Offset – is used to leave stock remaining on the part or to mill past the drive surface selected.
  • Cutting Side – defines the tool compensation setting for the feature as Center (none), Left, or Right. We selected Left to offset the toolpath to the outside of the part when cutting clockwise around the part. You would select Center when creating an engraving operation.
  • Cutting Side Offset – adds an additional offset of the toolpath from the projection curves. This is only used with the Cutting Side parameter set to Left or Right.
We did not change any other settings in this operation, but you can change the cut tolerance on this page. You could also tab to other pages for Tool Axis control to set this operation to 3X, 4X, or 5X toolpath and set a specific rotary axis. Other tabs include Gouge Check to check surfaces from gouging within the toolpath; Link to set the lead-in, lead-out, and linking between different areas of the part; Roughing if you want to add some roughing passes before the operation; and Utility for maximum angle steps around the rotary axis and other miscellaneous settings.
Here is the toolpath projected around the curved surfaces of the fixture. This functionality is available in the Mill 4X Pro package where the tool is able to rotate and move off of the centerline of the rotary axis.
Toolpath projected around the curved surfaces of the fixture
forum.bobcad.com
