Registration
There are two options to register your software program for BobCAD. The first option is to register automatically via the internet. As long as your computer is connected to the internet, you will simply have to enter your license ID and password to register the specific version of BobCAD. The licenses you purchase will be included in the information on your invoice after purchase.
The second option is to register the software program manually via e-mail. If you do not have the computer connected to the internet, you will need to type in your license ID and password, then download the request file when selecting this option. This file is essentially a text file that you will need to put on a flash drive. From there, you will move the flash drive to a computer that is connected to the internet. The file will need to be attached to an e-mail and sent to the e-mail address [email protected]. In about five to ten minutes, there will be a response file sent to your e-mail address. You will need to place this response file onto a flash drive, and transfer it to the original computer. In the registration page on the original computer, you will need to select the response file from the flash drive to register that version of BobCAD.
If the version of BobCAD is older than V30, or a version of BobCAM for Solidworks that is older than V6, you will have to contact our technical support team to register the software program offline. Under the Activate License option in these versions of BobCAD-CAM, there will be user codes that will populate that you will need to provide to a support technician. The support technician will enter these user codes on their side, then will be able to provide response codes to successfully register the older versions of BobCAD-CAM.
De-authorization
The de-authorization process is very easy in the newer versions of BobCAD-CAM. In our standalone version of BobCAD, you can go to File>Help, and then select the option Transfer License located at the middle of this page. You can again select to transfer your license automatically via the internet if the computer is online. On the next page, the license ID will be there to remind you which license you are transferring. After selecting next again, your license will be successfully transferred. You will then be able to register on a new computer. In BobCAM for Solidworks or for Rhino, this Transfer License page will be located under Help>BobCAM Help>Transfer License. Follow the same steps as stated previously to then transfer the license automatically via the internet.
There is also an option to de-authorize the newer versions of BobCAD-CAM manually via the internet, and the steps are very similar to registering manually via the internet. After selecting this option, you will need to type in your license ID and password, then save the license request file and put it onto a flash drive. This file will need to be put onto a computer that has an internet connection, where you can attach the file to an e-mail and be sent to [email protected]. In about five to ten minutes, a response file will be sent to you. You will need to place this response file onto a flash drive, and transfer it to the original computer. In the de-authorization page on the original computer, you will need to select the response file from the flash drive to e-authorize that version of BobCAD.
Again, if the version of BobCAD is older than V30, or a version of BobCAM for Solidworks that is older than V6, you will have to contact our technical support team to de-authorize the software program offline. There will be user codes to provide to a support technician of BobCAD. There will then be response codes for the support technician to provide to successfully de-authorize the license from that computer.
Manual De-authorization
If your computer or hard drive of the computer becomes unusable, please contact technical support so that we can manually release the license from that computer. This is meant as a last resort option, as the license comes up as a loss on our side if we need to manually release the license this way.
Our support site allows you to submit a ticket to technical support online: www.bobcadsupport.com
Our user forum is a community of other BobCAD-CAM users to share ideas and projects in BobCAD-CAM: forum.bobcad.com
Want to try it for yourself? Download NEW BobCAD V34!
