RS-232 is a method of communication between two electronic devices using a serial data protocol and it defines the hardware required. Serial communication is a method of communication that can be completed with as few as 3 wires yet also supports more advanced features requiring more wires in the cable. Each wire in the cable used can communicate in only a single direction.
An example of the simplest connection can be seen below:
In the above image you can see we have pin 2 on the left connected to pin 2 on the right. The left pin 2 is the RD (Receive Data) pin on the PC side of the connection. Pin 2 on the right is the TX (Transmit Data) pin on the controller side. We can also see that pin 3 on the left is connected to pin 3 on the right. On the left pin 3 is the TX (Transmit Data) pin and pin 3 on the right is the RD (Receive Data) pin. So the TX is connected to RD with this wiring. Pin 5 (left) and pin 7 (right) in this example are the SG (Signal Ground).
Ok, so now we have seen the simplest connection but what are the settings that make this communication work?
The common settings you will see in RS-232 communication software is shown below:
Overview of the Process
Using the selected COM port the system generates the transmission using the TX pin. The first transmission is a bit called the Start Bit. This start bit indicates to the receiver that the transmission of data is beginning and will follow. After this start bit comes the Data Bits. The Data Bits contain the actual data of the transmission. Next is the parity bit and finally the Stop Bit which indicates the end of the transmission for that chunk of data. Below is a brief overview of these specific parameters.
Parameters:
Baud Rate: The baud rate is the speed the communication will take place. The design of the RS-232 communication protocol does not provide for a signal to automatically synchronize the speed the data is transmitted; each device must be set to the same communication speed (Baud Rate) so the data can be successfully transmitted and received.
This speed is defined in Bits Per Second. So, an example would be 9600 baud. This means 9600 Bits Per Second. In a computer it takes 8 bits to represent a single character so RS-232 communication set at 9600 baud could transmit a maximum of 1200 characters per second. But there are other pieces of information that must also be transmitted so the actual number will be lower.
What is Handshaking?
Handshaking is used to allow the two devices to communicate in such a way so that the buffer on the receiving end does not get overwhelmed and communication can be “paused” to allow the receiving end clear some of the buffer before communication continues.
- Hardware Handshaking uses physical pin connections in the cable that must be connected to work. This is a more reliable handshaking method however it is used less often due to the extra wiring required. The signals and their meaning are:
- TR – Data Terminal Ready
- DSR – Data Set Ready
- RTS – Request To Send
- CTS – Clear To Send
- Software Handshaking is a method of flow control where special characters are inserted into the data stream to indicate for the sending unit to pause sending while the buffer empties on the receiving end. Once the buffer is ready for more data a resume character is then sent to signal to resume sending data. The characters used are commonly referred to as XOn and XOff.
The following is example RS-232 cable wiring between PC and CNC Controller to support software handshaking.
![RS-232 Db9 to DB25](https://bobcad.com/wp-content/uploads/2022/03/IMG-3-RS-232-DB9_to_DB25.png)
![RS-232 DB25 to DB25](https://bobcad.com/wp-content/uploads/2022/03/IMG-4-RS-232-DB25_to_DB25.png)
![RS-232 DB25 to DB9](https://bobcad.com/wp-content/uploads/2022/03/IMG-5-RS-232-DB25_to_DB9.png)
![RS-232 DB9 to DB9](https://bobcad.com/wp-content/uploads/2022/03/IMG-6-RS-232-DB9_to_DB9.png)
Using RS-232 communications with a Gen 1 HAAS? Click here for additional information.
forum.bobcad.com
