Tech Tuesday: What You Need To Optimally Run BobCAD Software
Posted October 17, 2017 5:25 pm   Published by    BobCAD-CAM ">
It’s often that I hear from CAD-CAM users, “Will the software run on my computer?”, or “If I get a new computer, what do you recommend I get for optimal performance?”. Whether you’re new to machining or a seasoned veteran, here are 5 boxes that you should check when evaluating if your CAD-CAM software will run optimally on your computer or not.
1. Operating System
BobCAD software is a Windows-based application and requires your computer to be current with either Windows 7, Windows 8 or Windows 10 in order to properly load and run BobCAD-CAM software. Optimal software performance requires a 64-bit version of Windows.
2. Processors
Your computer’s processor is the “engine” that directly affects the speed of loading and the computing of Toolpaths. Which is why I recommend Intel® or AMD® Processors that are in the 3.4 GHz range or greater. The 2.0 GHz processor will run BobCAD, but its speeds of processing will be slower.
3. Memory
Generally, adding RAM is a solid way to boost computer performance. As your computer runs out of RAM, it starts to write to the hard drive which begins to slow things down. Adding RAM is cost effective and relatively inexpensive to do ( prices could range from $150 to $250 ) to add between 6GB and 16GB. If you ask me, the boost in performance is well worth the price.
4. Video Card
BobCAD-CAM’s stability is dependant on your graphics card’s ability to process information. That’s why a dedicated graphics card is so important. Integrated graphics cards may work, but quickly run out of memory and everything slows down from there. It’s recommended to use an aftermarket graphics card that has a least 1 GB of memory. Generally, Nvidia performs best with our CAD-CAM software. Typically, the median cost for a Nvidia graphics card is around $200 dollars. Again, a low cost to add huge performance! With aftermarket graphics cards, you can fine-tune their performance by configuring the graphics driver to the BobCAD-CAM software. They also make it easy to update drives to keep your graphics running smoothly.
5. Monitor
It’s not the size of the monitor that matters, it’s the resolution. To display your windows and toolbars properly, a resolution of 1280×768 is needed. I personally prefer a higher resolution for a better the viewing experience. Many CAD-CAM users run 2, sometimes 3 monitors, which is super cool. But, if you really want to be on the cutting edge, get a huge 40” monitor and snap windows to the corners of your screen.
If you use these general guidelines for computing, your software should be running at its absolute best, providing you a seamless, smooth experience designing and machining. Remember, you don’t necessarily have to get a new computer if your software begins to slow down. Just evaluate its components with the checklist above and you should be fine. Thank you for reading another Tech Tuesday; see you next week!
For a link to the official System Requirements page, click HERE.
v31 cam software download
Every week there will be a blog post dedicated to the most common questions and concerns that I hear throughout the previous week from users of BobCAD-CAM software. My co-workers affectionately refer to me as Jimmy John due to my previous job at a sub shop, but now instead of serving chips, I write about them (pun intended)! Feel free to interact in the comments section and the next Tech Tuesday just might feature your question or concern.
