Cut time, not corners.
Programming a part shouldn’t feel like programming a spaceship. If you’re spending more time tweaking code than actually cutting chips, it’s time to rethink the way you work. Here are a few workflow tips—built for real machinists—backed up by software features that make your job faster, easier, and just a bit more satisfying.
1. Start with a Solid Setup
Before you start programming, get your house in order. Define your stock, your machine, your work offset, your tool library—everything. Not just because it’s good practice, but because skipping this step is like measuring with a rubber ruler.
Bonus Tip: Our Job Setup Manager helps you lock down your environment with zero guesswork. Define it once, reuse it everywhere.
2. Don’t Program Blind
Visibility matters. Set your toolpaths up so you can actually see what’s going on. Assign different colors to each toolpath to catch overlaps or missed regions at a glance. Then double-check the Tool Tree and Operation Tree to make sure your logic—and your machining order—makes sense.
Pro Tip: Color-coding your toolpaths and scanning the trees before simulating is a fast way to catch costly mistakes before they ever hit the machine.
3. Use Adaptive Toolpaths When Possible
Conventional stepovers might still have a place, but adaptive strategies save time, reduce wear, and just run smarter. If you’re not using them, you’re leaving efficiency on the table.
Pro Tip: Let the toolpath handle the hard stuff. Use Automatic Rest Machining to clean up leftover material intelligently instead of manually guessing where to cut.
4. Let the Software Handle the Details
You don’t need to manually micromanage every little cleanup pass. Use your software’s built-in logic to do the heavy lifting—especially when it comes to leftover material or reusing tool settings.
Pro Tip: Use Rest Finishing by Tool Diameter or STL-based stock detection to focus only on uncut areas. It cuts cycle time and saves your tooling—without you having to redraw boundaries.
5. Trim the Fat—Literally
Extra passes, unnecessary links, or cutting air? No thanks. The cleaner your toolpath, the faster your part comes off the machine.
Feature Tip: Use Smoothing options in your Advanced Roughing operations to reduce abrupt direction changes and generate cleaner, more efficient motion.
6. Edit Smart, Not Hard
Tweaking feeds, speeds, or depths after generating toolpath? That’s fine—just don’t regenerate everything from scratch every time.
Feature Tip: With the Fast Edit option in the CAM Tree, and Operation/Tool Trees you can directly change specific numbers like feedrate, spindle speed, or depth without having to rebuild the operation. A little tweak goes a long way.
7. Keep Your Tool List Tight
Don’t waste time scrolling through a bloated tool library when you only use the same 10 tools 90% of the time.
Feature Tip: Use the Tool Crib to create a focused, job-specific tool list. You’ll program faster, make fewer mistakes, and avoid calling out that one tool nobody’s touched in six years.
8. Optimize with Real-Time Feedback
Programming blind is for rookies. The more feedback you get from the system as you program, the smarter your choices become.
Feature Tip: Use the Simulation Run Speed slider and playback controls to watch how your tool engages in the cut. You’ll catch inefficient motion before it becomes wasted machine time.
Wrap It Up
Great programming is about speed, safety, and smarts. You’ve got the tools—use them. Whether it’s a smarter lead-in, a trimmed toolpath, or just letting the system figure out what to cut, optimizing your workflow is about working with your software—not around it.
