Tech Tuesday: 3 Axis CAD-CAM Toolpaths You Need to Know
Posted January 15, 2019 4:38 pm   Published by    BobCAD-CAM ">
BobCAD’s robust toolpath matrix is a great resource for users to utilize when deciding what CAD-CAM package they will need for the work they do. Some of them are pretty straightforward, but the majority could use some explaining. Let’s take a look at our 3 Axis toolpaths & see what cutting advantages BobCAD’s CNC software has to offer for superior machining quality.
Planar
This toolpath is available in the following BobCAD CAD-CAM modules: Express, 3 Axis Standard, 3 Axis Pro, 3 Axis Premium, 4 Axis Standard, 4 Axis Pro, 5 Axis Standard and 5 Axis Pro. Planar is a conventional 3D toolpath that moves back and forth following your 3D surfaces or solids. This motion is similar to how you traditionally mow your lawn. Also referred to as lace, raster or parallel.
planar cam software toolpath
Spiral
This toolpath is available in the following BobCAD CAD-CAM modules: 3 Axis Standard, 3 Axis Pro, 3 Axis Premium, 4 Axis Standard, 4 Axis Pro, 5 Axis Standard and 5 Axis Pro. The spiral toolpath is used to machine rounded shape details, allowing the toolpath to spiral in or out as it follows your surfaces/solids.
spiral cam software toolpath
Radial
This toolpath is available in the following BobCAD CAD-CAM modules: 3 Axis Standard, 3 Axis Pro, 3 Axis Premium, 4 Axis Standard, 4 Axis Pro, 5 Axis Standard and 5 Axis Pro. The radial toolpath can also assist in machining rounded shape details where the toolpath begins in the center and works its way to the outside or vice versa.
radial cam software toolpath
3D Plunge Roughing
This toolpath is available in the following BobCAD CAD-CAM modules: 3 Axis Standard, 3 Axis Pro, 3 Axis Premium, 4 Axis Standard, 4 Axis Pro, 5 Axis Standard and 5 Axis Pro. The 3D plunge roughing toolpath has a high material removal rate and is used to “drill” out material with tooling made for the plunging motion. This toolpath applies directly to surfaces and solids.
3d plunge rough cam software toolpath
Z Level Roughing
This toolpath is available in the following BobCAD CAD-CAM modules: 3 Axis Standard, 3 Axis Pro, 3 Axis Premium, 4 Axis Standard, 4 Axis Pro, 5 Axis Standard and 5 Axis Pro. The Z level roughing toolpath is a 3D roughing toolpath that is used as a 3D pocket routine. It removes material by following the surfaces or solids.
z level roughing cam software toolpath
Advanced Z Level Finishing
This toolpath is available in the following BobCAD CAD-CAM modules: 3 Axis Standard, 3 Axis Pro, 3 Axis Premium, 4 Axis Standard, 4 Axis Pro, 5 Axis Standard and 5 Axis Pro. Advanced z level finishing is also referred to as waterline and is a 3D finishing toolpath. It is used to machine the vertical surfaces of your part and users can choose from a single direction cut, bi-direction cut or spiral cut.
advanced z level finish in bobcad cam software; toolpath
Project Curves
This toolpath is available in the following BobCAD CAD-CAM modules: 3 Axis Pro, 3 Axis Premium, 4 Axis Pro, and 5 Axis Pro. Project curves is a 3D finishing/detail oriented toolpath that uses chosen wireframe to define toolpath direction. To clean up or detail greater areas of your part geometry, users can offset this toolpath in either direction; this gives you a greater level of control over cuts.
project curves toolpath in bobcad cam software
Advanced Planar
This toolpath is available in the following BobCAD CAD-CAM modules: 3 Axis Pro, 3 Axis Premium, 4 Axis Pro, and 5 Axis Pro. Advanced planar is an advanced 3D toolpath that moves back and forth following your 3D surfaces or solids. Also referred to as lace, raster or parallel. Choose from more pattern and option choices than the standard planar toolpath mentioned at the top of the article.
bobcad advanced planar cam software toolpath
Flatlands
This toolpath is available in the following BobCAD CAD-CAM modules: 3 Axis Pro, 3 Axis Premium, 4 Axis Pro, and 5 Axis Pro. Also known as horizontal, this toolpath will detect and machine those flat surfaces on your part.
flatlands bopbcad cam software toolpath
Equidistant Offset
This toolpath is available in the following BobCAD CAD-CAM modules: 3 Axis Pro, 3 Axis Premium, 4 Axis Pro, and 5 Axis Pro. Also referred to as scallop, equidistant offset is used as a ‘catch-all’ detailing/finishing toolpath. The main benefit of this toolpath is for stepping over to the surface area. This helps create a consistent finish on the steep & shallow areas of the part.
equidistant offset bobcad cam software toolpath
Pencil
This toolpath is available in the following BobCAD CAD-CAM modules: 3 Axis Pro, 3 Axis Premium, 4 Axis Pro, and 5 Axis Pro. The pencil toolpath is primarily used to clean up the inside corners on 3D projects. Take either a single pass or multiple passes to clean up smaller areas found at the cross sections of walls and floors.
pencil cam software toolpath
High Speed Roughing
This toolpath is available in the following BobCAD CAD-CAM modules: 3 Axis Pro, 3 Axis Premium, 4 Axis Pro, and 5 Axis Pro. High speed roughing allows users to achieve higher material removal rates through smooth tool motions for getting in and out of cuts.
high speed roughing in bobcad cam software
Rest Machining
This toolpath is available in the following BobCAD CAD-CAM modules: 3 Axis Pro, 3 Axis Premium, 4 Axis Pro, and 5 Axis Pro. Rest machining is a setting used to target left behind material from a previous cutter. It will target smaller slots/corners where a larger tool didn’t fit and clean the area up.
rest machining in bobcad v31 cam software
Morph Spiral Pocketing
This toolpath is available in the following BobCAD CAD-CAM modules: 3 Axis Pro, 3 Axis Premium, 4 Axis Pro, and 5 Axis Pro. The morph spiral pocketing toolpath is one of our advanced roughing patterns and uses a morph spiral motion to minimize direct linking from one toolpath pass to the other. This allows the tool to stay engaged in the material for more efficient tool motion.
morph spiral pocketing in bobcad cam software
Parallel Pocketing
This toolpath is available in the following BobCAD CAD-CAM modules: 3 Axis Pro, 3 Axis Premium, 4 Axis Pro, and 5 Axis Pro. Parallel pocketing is an advanced roughing pattern that uses a zig-zag method to work back and forth, clearing material within your part geometry.
parallel pocketing in bobcad cam software
Offset In Pocketing
This toolpath is available in the following BobCAD CAD-CAM modules: 3 Axis Pro, 3 Axis Premium, 4 Axis Pro, and 5 Axis Pro. Offset in pocketing is an advanced roughing pattern that utilizes an offset method to work its way outside the part towards the inside of your part geometry.
offset in pocket inside bobcads cam software
There you have it! These are the toolpaths we offer with our 3 Axis packages and this is what users can expect from them. If you want to learn more about BobCAD’s latest 3 Axis capabilities, click here. Thanks again for reading another Tech Tuesday; see you next week!
4 responses to “Tech Tuesday: 3 Axis CAD-CAM Toolpaths You Need to Know”
  1. Peter Georgi says:
    Hi, this was one of the most usefull Tech Tuesdays! Really great! Regards Peter
  2. Kobus Henning says:
    Does the software run on Linux?
