Today’s CNC software Quick Tip talks about creating a Tapered Wall Pocket using 3D toolpaths. This allows you to put a draft on the wall and to rough the pocket out.
If you are interested in seeing what BobCAD-CAM software can do to maximize your shop’s productivity & bottom line, download a copy and try it out today.
