BobCAD-CAM Upgrade: Boost Your 5-Axis Machining & Programming Efficiency
Posted August 12, 2025 8:58 am   Published by    BobCAD-CAM ">
Read the Article or Listen to the podcast:
Why Upgrading Your BobCAD-CAM for 5-Axis Machining is a Game-Changer
If you’re still running an older version of BobCAD-CAM, you’re missing out on major advances in 5-axis machining and 5-axis programming that can save you time, money, and frustration.
The latest BobCAD-CAM release transforms the way you program and cut complex parts. From high-speed roughing to intelligent collision detection, these tools let you push your 5-axis machine to its full potential.
Here’s what’s new — and why it matters for your shop.
Schedule a Demo of V37
1. High-Speed Roughing for 5-Axis Programming
Older versions limited you to basic roughing. The new version introduces high-speed roughing within 5-axis toolpaths, allowing you to remove material faster while extending tool life.
This not only boosts efficiency but also gives you more control over cutting strategies, whether you’re targeting a single feature or multiple areas.
2. Multi-Axis Finishing Without the Hassle
Finishing complex parts used to require multiple surface operations. With the latest upgrade, you can now:
  • Finish walls
  • Finish floors
  • Apply rest machining to leftover material
This streamlined 5-axis programming reduces tool changes, shortens cycle times, and improves surface quality.
3. Automatic Deburring for Cleaner Edges
Manual deburring is time-consuming. Now, BobCAD-CAM automatically detects edges and applies deburring toolpaths in your 5-axis machining workflow.
You can use tools like lollipop cutters for precision results and a consistent finish across every part.
4. Automatic Indexing (3+2 Machining)
Setting up each index manually slows you down. The new automatic indexing feature generates 3+2 toolpaths instantly, saving hours on complex parts. You can still fine-tune the positions in the wizard if needed.
5. Smarter Swarf Machining for 5-Axis Cuts
Swarf machining now supports chamfer tools, barrel tools, and more — with toolpaths that follow both the tool shape and the surface direction. This delivers more accurate cuts in fewer passes.
6. Surface-Based Retraction & Clearance Control
You can now define retractions and clearance positions directly from surfaces in your model, improving safety and efficiency while avoiding unnecessary air cutting.
7. Intelligent Impeller & Port Machining
In 5-axis programming, collision detection is a time sink — especially with impellers and ports. The new system recognizes when you’re cutting these geometries and adjusts automatically.
For impellers, it accounts for nearby blades. For port machining, it optimizes the path to avoid unnecessary checks.
8. Mill-Turn Capabilities Inside Multi-Axis
Even if you don’t have a dedicated lathe, you can now rough parts like a lathe directly inside your 5-axis machining environment, combining turning and milling into a single setup.
9. Automatic Tool Tilt Across All 3-Axis Pro Operations
All 3-axis Pro toolpaths now support automatic tool tilting. Simply set your collision detection rules and tilt angle — the system will tilt the tool automatically when needed, removing the need for manual tilt programming.
Why This Upgrade Matters for Your 5-Axis Machining
The latest BobCAD-CAM upgrade isn’t just about new features. It’s about programming smarter, cutting faster, and reducing costly errors in 5-axis machining.
By upgrading, you’ll:
  • Shorten programming time
  • Improve part quality
  • Extend tool life
  • Reduce setup complexity
If you want to unlock the full potential of your 5-axis machine, now’s the time to upgrade.
Send us your part, schedule a personalized demo, and see what the latest BobCAD-CAM can do for your 5-axis programming.
Ready to upgrade or learn more?
