CAM for SOLIDWORKS: Why It Still Makes Sense for Modern CNC Shops
Posted April 16, 2026 3:24 pm   Published by    BobCAD-CAM ">
Why CAM for SOLIDWORKS matters
CAM for SOLIDWORKS is still one of the smartest ways to work if your shop already relies on SOLIDWORKS for design and engineering.
For years, BobCAD has been known for its standalone CAD-CAM platform, but most people don’t realize that BobCAD also offers a CAM for SOLIDWORKS. This integration has been around for nearly 20 years, and even though BobCAD is a Gold Partner with SOLIDWORKS, many users still don’t fully take advantage of it.
That matters because many shops don’t want to jump between different systems every time a model change. If you already work inside SOLIDWORKS, staying in the same interface while programming your parts just makes sense.
At the end of the day, if you’re looking for a CAM for SOLIDWORKS, you’re not just looking for software—you’re looking for a more efficient workflow.
What associative programming really means
One of the biggest advantages of using a CAM for SOLIDWORKS is associativity.
What does that actually mean in real life?
If you modify your geometry inside SOLIDWORKS, your CAM process updates automatically with just a couple of clicks.
That’s huge.
Because if your CAM system is separate from your CAD system, every time there’s a revision, you’re forced to:
  • Re-import geometry
  • Re-select features
  • Rebuild toolpaths
  • Double-check everything again
That’s time. That’s money.
Working inside SOLIDWORKS gives you the ability to make changes as many times as needed without restarting your programming process.
For shops dealing with revisions, engineering changes, or customer updates, this alone can make a massive difference.
Why BobCAM for SOLIDWORKS stands out
There are multiple CAM options available for SOLIDWORKS, so the real question is not whether integration exists—it’s which solution gives you the best value.
BobCAM for SOLIDWORKS stands out because it combines:
  • Ease of use
  • Strong machining capability
  • And a much more accessible price point
A lot of high-end CAM systems offer advanced functionality, but they come with a cost that can easily go over $10,000–$15,000.
With BobCAM for SolidWorks, you’re getting access to high-level functionality at a price that makes sense for most shops, whether small or large.
And that’s really the key difference today.
Most CAD-CAM systems have similar capabilities—but not all of them offer the same value for the investment.
High-end CAM functionality without high-end cost
When you’re evaluating a CAM for SOLIDWORKS, what really matters is what you can actually do with it.
With BobCAM for SOLIDWORKS, you have access to functionality like:
These are features that are often associated with higher-end systems.
But here, you’re able to use them directly inside SOLIDWORKS, without needing a separate environment.
Another important advantage is the ability to work inside assemblies.
That means you can create different setups, manage multiple components, and program in a way that reflects how parts are actually machined in the real world.
Who should use CAM for SOLIDWORKS
A CAM for SOLIDWORKS makes sense if:
  • You already use SOLIDWORKS for design
  • You deal with frequent revisions or engineering changes
  • You want to reduce programming time
  • You’re looking for strong CAM capability without a high investment
  • You want to keep CAD and CAM in the same environment
  • You need a high-end CAD system
If that’s your situation, then this is not just a software choice—it’s a workflow decision that impacts your entire operation.
Explore what you might be missing
If you want to see what your system is actually capable of, take a few minutes to explore the Feature of the Day library.
This is a collection of real functionalities that has been added over time—features that many users already have but are not using.
You can explore it here:
https://bobcad.com/v2/video-library/
Chances are, you’ll find multiple tools and strategies you can start applying immediately to reduce cycle time and improve efficiency.
FAQ
What is CAM for SOLIDWORKS?
CAM for SOLIDWORKS is CAM software that runs directly inside the SOLIDWORKS interface, allowing you to create toolpaths and generate G-code without leaving your CAD environment.
Is BobCAM for SOLIDWORKS associative?
Yes. When you modify your geometry in SOLIDWORKS, your CAM operations can update automatically, reducing the need to rebuild programs.
Why choose BobCAM for SOLIDWORKS?
Because it offers strong machining capability, ease of use, and a better price-to-performance ratio compared to many higher-cost CAM systems.
Can I program assemblies in CAM for SOLIDWORKS?
Yes. You can work inside assemblies, create setups, and program parts in a way that reflects real machining conditions.
Final thought
If you’re looking for a CAM for SOLIDWORKS, the goal is not just to find something that works.
The goal is to find something that improves how your shop operates.
Because at the end of the day, the biggest gains don’t come from buying new tools.
They come from using the tools you already have—better.
