Questions?
Call Us to speak with a CAD CAM Pro!
Feedrate Control Update for 3D Milling
Improvements to feedrate control make it’s way into one of the most used 3D machining toolpaths, equidistant offset. This toolpath is popular with anyone using it due to its consistent finish along steep and shallow surfaces, unlike the planar and Z-level finish, which is suitable for one and not the other.
Planar- Best for Milling 3D Shallow Surfaces
Z Level – Best for Milling 3D Steep Surfaces
Adaptive Stepover Options for 3D Milling
Z Level and Planar both have options to adapt the stepover, adding additional passes to improve surface finish on either the steep or shallow areas.
Equidistant addresses both steep and shallow surface areas equally; for most, it’s their go-to semi-finish or finishing toolpath.
New 3D Milling Feedrate Control
To speed up a 3D Milling job have you turn the feed handle up and down, standing at the machine or making someone stand at the machine to help cut cycle times? This New option does it for you in the code, automatically taking your entered feedrate and reducing it by a % range as the tool changes directions on corner moves.
Safe Feedrates are costing you money!
It’s true most shops turn to equidistant because it’s a powerhouse of a toolpath for 3D milling. This toolpath climbs up, down, and over outside and inside corners. The tool engagement spikes require slower federates to avoid tool breakages. If you are running the whole job with a single feedrate, try this new feature! Posting NC programs with feedrates that ramp up and down for you, allowing you the maximize machine time.
Recent updates put additional feedrate control to adjust lead in/out moves, up and down cutting, and now corner speed.
Use these override settings to ramp up and down federates where needed automatically.
Feedrate control to optimize cycle time & Efficiency
Use feedrate control to reduce cycle times by as much at 90%! Huge savings to be had for any manufacturer machining 3D parts with this popular toolpath operation.
Download & Try the New BobCAD-CAM, BobCAM for SOLIDWORKS or BobCAM for RHINO
Over the last 3 years, over 200 new features were added to the system, Be part of BobCAD-CAM’s progress by participating in our R&D surveys!
Are your machines and projects getting more complicated? Ready for CAD CAM software that helps you yield more throughput? Software that comes with training to ensure greater productivity! Call 727-442-3554 to learn about BobCAD CAM.
