Did you know you can profile cut in 5 Axis using a Swarf Toolpath? Surface-based toolpaths designed for 5 Axis.
Download & Try It Today!
5 Axis Profile Cutting
Maybe you didn’t consider swarf milling as an option for 5 Axis profile cuts, but you should. This well-developed toolpath makes easy work of 5 Axis machining when using drive surfaces. For jobs with only wireframe geometry, your next option would be to use 5 Axis wire frame, another common toolpath used in 5-Axis profile machining where swarf uses the surface geometry to drive tilt and control cutting, where as 5 Axis wireframe uses tilt lines to define tool orientation around corners and along curves.
Do Job Templates Save Time When 5 AXis Profile Cutting?
When creating a CAM Tree job from the start, there are many steps and things to set up for a 5 Axis profile job. Things like picking your machine, post, tools, stock, and standard machining features and setting to program your 5-axis machine.
What if you could cut your programming time in half by reusing CAM Tree jobs and all their setting for future jobs? Thereby eliminating many of the “ setup steps “ that are required when setting up a job or specific application for the first time.
How are templates different from Save & Loading Machining Features?
Until recent releases, you could not save and reuse the “Whole CAM Tree”, you could save machining features which was a huge time saver. Now with CAM Tree templates, you can save your stock, zero, tools, machining features, and job-specific settings with a single click.
Job Tree Templates is designed to make it easier to capture and reuse job setting, tools and CAM Tree machining features.
Making it easy to capture and reuse what works, while making it easier to establish programming standards in your shop.
Over the last 3 years, over 200 new features were added to the system, Be part of BobCAD-CAM’s progress by participating in our R&D surveys!
Are your machines and projects getting more complicated? Ready for CAD CAM software that helps you yield more throughput? Software that comes with training to ensure greater productivity! Call 727-442-3554 to learn about BobCAD CAM Membership Plans. ( not the renting software kind )
Click here to learn about what’s included.
