Tech Tuesday: 2 Axis Wire EDM Sample – Land and Taper
Posted December 14, 2021 3:48 pm   Published by    BobCAD-CAM ">
BobCAD V34 and BobCAM for Rhino V1 offer 2 Axis and 4 Axis Wire EDM machining. These two types of Wire EDM cuts include inside, outside, or open cuts. If the taper angle is not continuous along the path you are expecting to follow, you will select a 4 Axis Wire EDM operation. You would then select the type of cut accordingly, whether it is an open, inside or outside path. Then, select the top chain and then the bottom chain for the wire to follow along and sync up to both paths. If the taper angle is continuous, you would need to simply select a 2 Axis Wire EDM operation. There is a setting in the 2 Axis Wire EDM operations to set a taper angle conveniently without creating any additional geometry. In this example, we will be exploring the 2 Axis Wire EDM paths and setting a land and taper along the path.
We begin by creating a two-dimensional drawing of the outermost boundary of the path of the wire. Then, go to the CAM tab and select Wire EDM for your machining job. Select your machine, and then go into the Stock Wizard to define the stock you have set up at your machine.
2 Axis Wire EDM Stock Definition
In this example, we will be creating a land and taper around the inside of this two dimensional drawing shown here. As mentioned previously, the 2 Axis Wire EDM operations offer a setting to define the land and taper of the part without needing to create any additional geometry on the CAD side of things. After defining the stock, you will right-click on Machine Setup – 1 and select a Wire EDM operation. In this example, I chose Two Axis Open for an inside cut around the part.
Note: The Land and Taper setting is only available for 2 Axis Inside features and 2 Axis Open features set to Process As Die (inside)
The first page that opens offers settings for the upper guide and lower guide, punch or die, glue stop (a tab to leave for the cut out to fall out later), and Taper Settings.
2 Axis Wire EDM Wizard
The Land and Taper option applies a fixed taper cut in addition to a land cut which contains no taper. Typically, the Rough Cut operation cuts the taper portion of the feature, and the Skim Cut operation cuts the land or non-tapered portion of the feature. This option is used to create a relief cut above or below the land portion using the following options.
  • Taper Angle– determines the amount of taper applied to the taper portion of the feature. For 2 Axis Inside features, the value must be positive and the software automatically creates the proper taper for the feature. For 2 Axis Open features (set to Die) you define a positive or negative taper angle based on the chain direction of the feature.
  • Land Height – sets the vertical distance of the land portion for Land and Taper features.
  • Land On Top
Select this check box to apply the land to the top of the feature.
Here is the difference between the standard inside cut path without the land and taper option, and an inside cut path with the land and taper option set to a ten degree taper angle and land height at 0.25 inches.
This convenient way of creating a land and taper operation is available in our BobCAD standalone V34 and BobCAM for Rhino V1.
forum.bobcad.com
