A new feature in V33, BobCAD-CAM now supports Barrel Mills for most operations. More and more companies are turning to Barrel Mills. Cutting with Barrel Mills can save an unbelievable amount of time and money. Until now, we’ve had no way to support these tools in your operations, but after working hand in hand with Melin Tool Company to test and retest, we can give you a product that puts this amazing tool in your hands. BobCAD-CAM offers four different types of barrel mill tools in 3 Axis milling and Mill 4 Axis Standard packages. Two additional barrel mill types can be utilized with the Mill 4 Axis Pro surface based toolpaths. See the diagram below to get an idea of why these tools are quickly becoming the standard.
In the diagram, you can see the smaller step over that is necessary for the ball endmill versus the barrel mill tool. Also the cusp height, or scallop height, is noticeably smaller when using the barrel mill tool. This means with the barrel mill tool, you will have less passes and a better tolerance on a part when using this toolpath down tapered walls. When programming with barrel mill tools, you can save time in machining and also cut your parts with a better tolerance level.
Here are the four different types of barrel mill tools that are now standard in V33:
With these types of tools, you can program a barrel mill tool with a much deeper step down and still leave the desired cusp height. It’s easy to see how these tool shapes can save so much time!
Download a demo of V33 today and try out Barrel Mill Tool Support!
BobCAD-CAM has provided CAD-CAM CNC Software products to the global manufacturing industry for over 30 years. BobCAD-CAM software can be found to increase CNC productivity for many applications in aerospace, automotive, production manufacturing, mold making, general machining, woodworking as well as the medical manufacturing industry, consumer products, musical instruments, custom fabrication, defense industry and many others due to the products ability to automatically generate NC programming code for such a wide variety of CNC controllers. BobCAD-CAM software is also found in educational institutions throughout the world as well as independent hobby home use. Products include machining technology for 2, 3, 4 & 5 Axis CNC Milling, Routing, Waterjet, Plasma and Laser machines as well as 2 Axis CNC Lathe. BobCAD-CAM is modular allowing shops to start off at a reduced technology level and add technology as it is needed including an add-on, BobART, for artistic machining. Unique technology includes adaptive high-speed machining multiaxis milling and routing which is a first in the world of CAD-CAM software. BobCAD-CAM also provides a variety of quality training products that include regional and online training classes or private sessions tailored to specific applications. Professional certification and multi-tiered support solutions are available.
