There is a new feature in BobCAD for pocketing, Drill Tip Positions to define the pilot hole location for your pocketing cycles to start the tool in. Prior to versions being limited to a single position, V33 now supports multiple Drill Tip Positions (pilot hole locations) for a single pocket operation.
Did you know BobCAD now offers multiple pilot hole locations for pocket features? When cutting pockets sometimes it makes sense to drill a feeder hole for the pocket cycle to start in. Instead of ramping down, users drill pilot holes for the pocket cycle to start in. In the past if you had multiple pocket boundaries with pilot holes, you would need to create a machining feature for each pocket boundary to allow for multiple pilot hole starts. New in BobCAD’s pocket features is supporting multiple pilot hole locations for a single pocketing machining feature.
The workflow for the new Drill Tip Position feature is very simple. After you have completed your pocketing operation, you expand the operation in the CAM Tree. Right-click on the Drill Tip Position option below the pocket operation and click Select. Pick the points you want to create pilot holes in before starting your pocketing operation. Click OK, then compute the new toolpath for your pilot holes.
BobCAD now makes it easier to program pocketing cycles with multiple pilot hole locations. To define the pilot hole location (what we call the drill tip position in BobCAD) make sure to select points that the Z depth the holes were drilled to. A common workflow issue for new users is to select points that are at Z0, vs the absolute depth of the pilot hole. Make sure you select drill tip position points that at the Z level the pilot holes were drilled to.
Download our Free Trial and try it yourself!
BobCAD-CAM has provided CAD-CAM CNC Software products to the global manufacturing industry for over 30 years. BobCAD-CAM software can be found to increase CNC productivity for many applications in aerospace, automotive, production manufacturing, mold making, general machining, woodworking as well as the medical manufacturing industry, consumer products, musical instruments, custom fabrication, defense industry and many others due to the products ability to automatically generate NC programming code for such a wide variety of CNC controllers. BobCAD-CAM software is also found in educational institutions throughout the world as well as independent hobby home use. Products include machining technology for 2, 3, 4 & 5 Axis CNC Milling, Routing, Waterjet, Plasma and Laser machines as well as 2 Axis CNC Lathe. BobCAD-CAM is modular allowing shops to start off at a reduced technology level and add technology as it is needed including an add-on, BobART, for artistic machining. Unique technology includes adaptive high-speed machining multiaxis milling and routing which is a first in the world of CAD-CAM software. BobCAD-CAM also provides a variety of quality training products that include regional and online training classes or private sessions tailored to specific applications. Professional certification and multi-tiered support solutions are available.
