Tech Tuesday: How to Apply Machine or Wear Compensation
Posted January 11, 2022 4:20 pm   Published by    BobCAD-CAM ">
BobCAD-CAM is able to support different types of compensation for your milling tools in milling operations. Understanding our terminology for tool compensation types will help with your specific milling strategy. We will be focusing on a profile operation under the Mill 2 Axis Wizard. You can see there are two drop-down options for compensation, system and machine compensation.
In some cases, we may want the center of the tool to follow the path we select, but in most cases, the path we choose represents the final surface of our finished product which would be ruined if the center of the tool were to travel along it. This is where our compensation choices come in. With compensation we can specify whether the center of the tool should move along the selected path, or whether the tool should follow an offset path based on the radius of the tool. If the tool is to follow an offset path, should that path be offset to the left of the tool direction, or to the right? For every 2 Axis CAM operation in BobCAD-CAM we decide how to handle this with System Compensation, and Machine Compensation:
Mill 2 Axis Wizard System and Machine Compensation
System Compensation:
The compensation is handled in the toolpath of the operation. The toolpath itself will be offset from the selected geometry, and the output code will follow this toolpath. With this option On, the system offsets the geometry by the tool radius. With this option Off, you should use Machine Compensation.
  • Off – the toolpath is calculated from the center line.
  • Left – the toolpath is calculated to the left of the selected contour.
  • Right – the toolpath is calculated to the right of the selected contour.
These options only affect the output in the posted code. The compensation is handled at the machine controller. BobCAD-CAM will output the codes for cutter compensation specified in the post, and the desired offset can be entered at the controller. The toolpath itself, and the coordinates of the output path, will not be affected by this compensation option.
  • Comp Left (G41) – the toolpath of the operation represents the center of the cutter. The post processed code includes the command for cutter compensation to the left of the contour.
  • Comp Right (G42) – the toolpath of the operation represents the center of the cutter. The post processed code includes the command for cutter compensation to the right of the contour.
Note: For machine compensation, you will need to use any lead-in except for Vertical. This is because there is no X or Y location to offset for the tool radius. Go to the Leads page and change the lead-in from Vertical to a different lead-in.
Mill 2 Axis Wizard - Profile Finish
For the path shown below, we have system compensation turned off and machine compensation turned on. It is set to offset to the right of the path, outputting G42 in the posted code for the machine to offset the tool to the right of the profile path. The G41 and G42 codes being output at the machine allows users to set additional compensation settings at the machine, like tool wear compensation for example.
Posting
This information is also found in our Knowledgebase for common questions about various functions in BobCAD-CAM. Our Knowledgebase documentation can be found here:
www.bobcadsupport.com
forum.bobcad.com
2 responses to “Tech Tuesday: How to Apply Machine or Wear Compensation”
  1. Peter Jacques says:
    Having issues with System compensation and machine compensation. When opening up a bore using the same tool to both rough and finish. Used System Compensation (Left) to rough with Machine compensation off. Tried to use system compensation G41 but the tool would gouge into the side of the bore. Used System compensation left and Machine compensation (Left/G41) on the finish to control the bore size. Had to remove the tool Diameter D offset on the setting page and use the Wear diameter to control the diameter of the bore. Had to add a D offset in the code to get the code to run right. How do I use System comp or Machine comp in order to control the bore size using the same tool to rough and finish whilst leaving the D offset diameter (.375) still in the offset page ? Tried to run finish pass with a .250 blend using G41 and the program came up with a “tool too big” error. I think the issue might be that The HAAS controller reads the tool offset in diameter but when using G41/G42 the machine processes the code radially. I believe this is a post processor issue.
    • Al DePoalo says:
      You could consider using a different D offset for each operation. Using the same tool posting different D values to allow for adjustment at the controller for both the rough and finish when using different styles of comp. This way you have independent control.
      In your example, you likely don’t have much clearance for the lead-in. Using machine compensation and system compensation allows you to offset for the tool and use the control table to adjust for the finish. Your lead in value will need to be greater than the D value offset. Learn more about BobCAD and cutter comp here. https://bobcadsupport.com/knowledgebase/apply-cutter-compensation-in-bobcad-cam/
      Otherwise use system comp, on the rough operation and system comp + machine comp for the finish. Using the D / wear value for finishing adjustments.
