Tech Tuesday: V32 – Top 3 Upgrades That Users Will Love
Posted October 8, 2019 8:05 pm   Published by    BobCAD-CAM ">
Happy release day! We are proud to introduce the brand new V32 CAD-CAM software to machinists all across the globe! V32 boasts dozens of upgrades and enhancements, touching all aspects of the software. “We are excited to deliver the next generation of BobCAD-CAM software to our customers,” says Greg Myers, BobCAD’s Director of Software Development.
You will be very pleased to learn that we can now accept Rhino 6 File imports. Previously, BobCAD had only been able to accept imported files up to Rhino 4. For today’s Tech Tuesday I pulled the top 3 new additions to the software that I truly believe users will love about V32:
  • Document Templates
  • Assigning Fixtures in Mill
  • Define & View Chuck Jaws in Mill Turn
    1. Document Templates
    V32 users can now save an entire file as a template. When you select the template, that file is recreated as a new document. Save yourself steps and time with the new document templates command. This modern functionality can be utilized in a bunch of different ways, such as the following:
  • A lot of companies offer a particular series of parts that feature slight variations between them. Using the document templates, you can create the base geometry of the model and then save that as a template. Once the first variation has been completed all you have to do is open the base geometry template so the next iteration is already half done.
  • In some cases, the same stock is used for many different job types. All you have to do now is import the fixture, create a job, set the stock, Machine Setup location, clearance values and Work Offsets. Once that is done, simply save the file as a template. You can now use that template anytime that stock is being used, meaning your work is already done!
  • Sometimes customers use a variety of document styles for different situations. There were 2 options in the past for changing documents: Part Settings (the current document) and Default Settings (future documents). This typically meant that users who were frequently using different settings had to change those settings back and forth a lot. That is no longer the case. You can now create document templates to handle all the cases you may want to use without ever having to go back & touch the settings dialog again. Just select one of your templates in the Backstage and you are ready to go!
  • Sometimes the same basic operations are used on almost every part: a couple of profiles, a couple of pockets and maybe a drilling operation or 2. With the new document templates in BobCAD, you can easily create a job with those same features and operations, saving the file as a template. Simply open the template, merge the appropriate file and your job is almost done! The only thing left for you to do is to associate geometry and the proper depths to each feature, compute and the job is complete! Pretty awesome, right?
    However you see fit to use the new document templates, the result is the same: fewer steps that save you valuable machining time.
    2. Assigning Fixtures
    You asked for it and we added it to the software! Now users have the ability to view the fixtures being used for various machine setups and can check them for potential collisions. Easily assign a fixture for each machine setup. It’s as simple as “1, 2, 3!” Just right-click the fixture item under the associated machine setup and select/reselect, then pick the fixture geometry as it appears in the proper configuration and select OK to save. This can be repeated for as many machine setups as necessary. Now, when you run your next simulation you will be able to see the selected fixture geometry in the configuration it was selected in for each of your setups.
    3. Define & View Chuck Jaws
    Now, for the first time ever, BobCAD is offering machinists a simple solution to quickly define chuck jaws in the user interface, allowing them to be viewed in simulation. You now have the ability to easily check jaws for collisions, verify jaws opening and closing, spinning, & even syncing properly for part transfers.
    So there you have it, these are my top 3 choices for the new V32 enhancements that I’m sure will be a fan favorite amongst new users. Want to see the rest of the enhancements that came to V32? Click here! To try out the new software, click the link below. Make sure to leave a comment and tell us what YOUR favorite new feature is.
    bobcad v32 cnc software
