Tech Tuesday: Speed Up Drawing in CAD with BobCAD’s Shape Library & Boolean Add
Posted September 3, 2019 5:31 pm   Published by    BobCAD-CAM ">
Welcome to another wonderful edition of Tech Tuesday. Today I am going to be teaching BobCAD users how to use the shape library & boolean add function. These time-saving functions allow users to make parts in CAD quickly & easily! Let’s get started.
For starters, I went to my Create 2D tab and drew a simple rectangle. The dimension of my rectangle is 6 inches long and 3 inches wide. Once I set my desired parameters for my rectangle, I go up to the shape library. BobCAD’s shape library has 40 common shapes to choose from. For this example, I am going to select the CAM Plate.
bobcad cnc software
For the origin, I am going to input 1.75 for my X value and .75 for my Y value. That will put my CAM plate at the top right center of my rectangle.
bobcad cnc software
To duplicate my plate, I am going to select the “Flip X” box in my Parameters window. To get the CAM plate on the bottom right part, simply input a negative value for Y (-.75).
bobcad cnc software
I am going to do the same thing for the left side and now I have all 4 corners of my rectangle with an intersecting CAM plate running through it. For my convenience, I like to see my entire model in one window. To do so, I can either select my graphics area and hit ‘F’ or I can hit the magnifying glass with the letter ‘A’ in it to get the same effect.
bobcad cnc software
The next chess move is to go back into our Create 2D tab and select 2D Boolean. The 2D Boolean function in BobCAD allows you to add, subtract or intersect groups. In this case, we will be adding. To populate the First Geometry Group box, we are going to hit shift and left-click on our rectangle. As you can see, all 4 lines of our rectangle are selected and indicated via a red color.
bobcad cam software
Next, take your mouse and click on the Second Geometry Group box. Hold shift and left-click on the outside of all of the CAM plates until they are all selected and you see a bold line outlining your part.
bobcad's cnc software
As I hit OK to save my progress, you can see that the part updates accordingly and our part now goes from 5 individual shapes to one solid shape.
bobcad cnc software
With BobCAD-CAM, drawing parts is that easy! Thank you for reading another Tech Tuesday; see you next week!
Try Our Latest Software Version & Start Cutting Today!
  1. Charley Briggs says:
    This was very interesting, I can’t wait to try it out. I can see how this process can save valuable time, thank-you…
  2. Charley Briggs says:
  3. Charley Briggs says:
    Excellent time saver…
