BobCAD’s robust toolpath matrix is a great resource for users to utilize when deciding what CAD-CAM package they will need for the work they do. Some of them are pretty straightforward, but the majority could use some explaining. Moving right along with our 4 Axis toolpaths, let’s see what cutting advantages BobCAD’s CAM software has to offer for superior machining quality.
Indexing
Indexing is available in our 4 Axis Standard, 4 Axis Pro, 5 Axis Standard & 5 Axis Pro modules. This toolpath is essential for indexing your part’s position to gain access to machining various features at different rotation angles.
Wrapping
Wrapping is available in our 4 Axis Standard, 4 Axis Pro, 5 Axis Standard & 5 Axis Pro modules. This toolpath helps users program holes, pocket, text, slot & more using your machine’s 4th Axis. Often referred to as axis substitution, wrapping groups allows users to program machining features found on the outside diameter of your parts.
Rotary
Rotary is available in our 4 Axis Standard, 4 Axis Pro, 5 Axis Standard & 5 Axis Pro modules. This toolpath drives along your 3D models, using your rotary axis to index for the next cut or to rotate the part while the tool moves up/down in Z following part geometry.
There you have it! These are the toolpaths we offer with our 4 Axis packages and this is what users can expect from them. If you want to learn more about BobCAD’s latest 4 Axis capabilities,
click here.
