5 Axis CAD-CAM Toolpaths You Need to Know
Posted January 2, 2019 4:18 pm   Published by    BobCAD-CAM ">
BobCAD’s robust toolpath matrix is a great resource for users to utilize when deciding what CAD-CAM package they will need for the work they do. Some of them are pretty straightforward, but the majority could use some explaining. Starting with our 5 Axis toolpaths, let’s see what cutting advantages BobCAD’s CAM software has to offer for superior machining quality.
Trimming
Trimming is available in both our 5 Axis Standard and 5 Axis Pro module. This toolpath is designed to machine along the profiles of your part geometry in 5 Axis. It uses drive curves & orientation lines, which means users are able to control the tilt of the tool as it follows your part profiles around corners & windows.
bobcad trimming cam software toolpath
Indexing
Indexing comes with both our 5 Axis Standard and 5 Axis Pro module. This toolpath comes in handy for indexing your part’s position, providing access to machining various features with the use of 2 rotation angles.
indexing in bobncad cam software
Swarf Machining
This toolpath is only available with our 5 Axis Pro module and is used to machine tapers, walls and surface with the side of your cutter.
swarf machining in bobcad cam software
High Speed Multiaxis Roughing
This toolpath is only available with our 5 Axis Pro module and is used to rough out your part geometry.
bobcad multiaxis roughing toolpath in bobcad cadcam
Rest Machining
This toolpath is only available with our 5 Axis Pro module and is a toolpath setting used to go after material that’s left behind from a previous cutter. It targets those smaller slots and corners where a much bigger tool couldn’t reach; rest machining comes behinds and finishes these areas.
bobcad cadcam rest machining
There you have it! These are the toolpaths we offer with our 5 Axis packages and this is what users can expect from them. If you want to learn more about BobCAD’s latest 5 Axis capabilities, click here.
v31 cam software download
