Tech Tuesday: Know BobCAD’s V31 CAM Software Standard NCEditor
Posted April 2, 2019 10:40 am   Published by    BobCAD-CAM ">
This week we are going to cover the Standard NcEditor in BobCAD-CAM V31 (replacing Predator Editor). Thanks in large to us working hand-in-hand with ModuleWorks, BobCAD-CAM’s new NcEditor is a step into the future of modern manufacturing. Our new editor, just like Predator Editor in previous versions, comes standard in our CAM software & is available for upgrade (Pro NcEditor).
bobcad cnc software nc editor
Standard NcEditor
As our longtime users may be familiar with in previous versions, Predator Editor was basically just Notepad with DNC capabilities. So, what happened when people wanted to use syntax highlighting or adjust feedrates, and spindle speeds without having to search through the code? You needed the Pro Editor from BobCAD. Put that in the past with V31; in the new NcEditor, all of this and more is available in the Standard version!
Admittedly, our old editor had a few drawbacks. In the new NcEditor, users are equipted with an intuitive user interface called the Job Setup. The job setup, which is set automatically when launched from BobCAD-CAM allows you to also easily set up older programs by allowing you to create a new job setup to use, save job setups to use later, select a machine, assign a target part & set its color and assign stock geometry & set its color.
Use the Tool Manager section to:
Create 12 different tool styles
Create Arbors
Create Holders
Create Tool Assemblies
Create Adapters
Use the Setup section to:
Create Stock
Create Tool Assignments
Create Work, and Tool Offsets
BobCAD’s Standard NC Editor Delivers…
• Color text, renumber, feeds and speeds override and calculator built-in
• Baud rate up to 115,200
We couldn’t be happier to offer our customers a standard editor with more features that are easier to use. With all of this power, the new NcEditor will make editing code easier than ever! Thank you very much for reading Tech Tuesday. To get articles like these delivered directly to your email, make sure to subscribe using the form above! See you next week!
v31 cam software download
4 responses to “Tech Tuesday: Know BobCAD’s V31 CAM Software Standard NCEditor”
  1. Nizam says:
    Very informative about NC editor. Several available options I haven’t tired yet.
    • Mike Downss says:
      Glad you liked it! Yes, many good things in the Standard and Pro versions of our new NcEditor.
  2. Shineworld says:
    I’ve the V31 full package.
    The NC editor icon is enabled but pressing it nothing happened
