Tech Tuesday: Select Same Sized Holes Easily with BobCAD’s V31 CNC Software [Quick Tip]
Posted January 29, 2019 11:38 am   Published by    BobCAD-CAM ">
Are you looking for a faster way to select hole sizes that are the same? Let’s take a look at how V31 makes doing this easier by using the Pick and Match selection feature.
We start with our subplate (below) that has a number of different sized holes on it that we would like to drill out or machine.
holes on a subplate in bobcad cnc software
Part of our selection process allows us to pick and match by color, layer or line style. Since we are not in a machining function, the first step we need to do is choose Selection mode.
selection mode in bobcad v31 cam software
Once we are in Selection mode, we can set the Pick and Match option. For this example, we are going to use the Pick and Match by Radius function (pictured below).
v31 cam software pick and match feature
With that selected, we can cursor over any radius and simply left-click. The software then automatically picks all the holes with the same size. It’s that easy with the latest V31 CNC software from BobCAD. Thank you again for reading yet another Tech Tuesday; see you next week!
auto hole selection in bobcad v31 cnc software
v31 cam software download
2 responses to “Tech Tuesday: Select Same Sized Holes Easily with BobCAD’s V31 CNC Software [Quick Tip]”
  1. David Perrine says:
    Subscribing to BobCad’s youtube channel
