CAD-CAM Software for 2D and 3D CNC Machine Programming
Posted April 20, 2018 2:23 am   Published by    BobCAD-CAM ">
CAD-CAM software has everything to do with modern CNC machine programming and plays a critical role in the future success of manufacturing at a global level. Manufacturers are continuously looking for solutions to improving CNC automation that is efficient, safe and takes the most profitable route to making parts.
When it comes to CAD-CAM programming, the programmer/operator can look at a part model and determine the right machining strategies that will lead to a finished part and then heavily relies on computer-aided machining software capabilities to get the right results. This is where a quality CAM system that offers the widest variety of 2D & 3D cutting strategies becomes the winner. Determining the best 2D vs. 3D cutting Toolpath strategies is easier than you might think, yet still commands a certain level of training to fully understand how the operations work and the results that can be achieved by using them.
Simulation In 2D/3D CAD-CAM
Look for cost-effective CAD-CAM that provides:
2D Machine Toolpath Strategies
3D Machine Toolpath Strategies
Simulation
NC Editor
Customizable Post Processing
Excellent Training
Understanding 2D CAM Programming
2D Toolpaths are based on wireframe*. Generally, if you are drawing a part from scratch you use points lines and arc to create your geometry. Once you’ve drawn the features you need to machine in the part you’ll apply 2D toolpaths for machining.
2D Wire Frame types used in CAM include:
Points
Lines
ARCS
Other Shapes
Splines
These types of geometries can be used for drawing profiles to be machined and more that include boundary geometry that is used to contain toolpath into a specific region of a part model.
2D Programming in CAD-CAM
2D CAM Programming Operations:
Drilling
Facing
Profile
Pocketing
Thread Milling
Engraving
Chamfer
Corner Rounding
Plunge Rough
These machining operations are available through Dynamic Machine Strategy™ functionality where the user can use multiple operations for individual CAD features. This streamlines creating the machining operations and simplifies the process as the user can get more done in less CAM moves.
Note that if you’ve imported a file or choose to create a solid model of your part you can use surface edges as boundaries for 2D toolpaths, and you can use surface edges to define the depth of your Toolpaths.
Understanding 3D CAM Programming
3D drawings mostly are based on wireframe boundaries that are used to create surfaces or solids. There are Surfacing / Solids features that do not require any wire fame, they use user input as an example, primitive solids shapes. Also, you can use surface edges to create additional surfaces or solids.
3D geometry types and functionality used to create Surfaces include:
Rectangular Plane
Circular Plane
Planar
Extrude Curve
Extrude Surface
Revolve
Sweep
Cross Section
Skin
Offset
3 Edge
4 Edge
Multisided Patch
Fillet
Swung
Ruled
3D primitive Solids include:
Sphere
Cube
Code
Cylinder
Torus
Fillet
Primitive solids are used in combination with solid Boolean editing features to create solid models.
3D Surface /Solid Editing Features:3 Axis Toolpath 1
Add
Subtract
Intersect
Split
Shell
Extrude Boss
Extrude Cut
Extend
Intersection Curves
Untrim Surface
Break Surface
Section
Scale
Now that you have a 3D surface or solid you can apply 3D toolpath to them. 3D toolpath cut where and to the surfaces you have selected. So unlike 2D toolpath where you define a boundary and depth, 3D Toolpaths are applied to the model directly, where they cut and how deep is based on the surface or solid directly.
3D Toolpaths Surface that are Solid Based:
Z Level Rough
Z Level Finish
Planar
Spiral
Radial
Plunge Rough
Advanced Rough
Flatlands
Equidistant offset
Pencil
Advanced Planar
Project Curves
Advanced Z Level Finish
3D Toolpaths that are Surface Based Only: Intro to Lathe
Parallel Cuts
Cuts Along Curve
Morph Between 2 Curves (Flowline style machine toolpath)
Parallel To Multiple Curves
Project Curves
Morph Between 2 Surfaces
Parallel To Surface
Cutting options you use in 3D Toolpaths affect where Toolpath is created. Toolpaths are created based on the model surfaces you’ve selected, and depending on the cutting options for that Toolpath like the stock for finish, DOC, boundary, operational stock, surfaces you’ve select to avoid ( check surfaces ) affect where material s left over or targeted for cleanup.
2D CAD-CAM will always have a place in machine shops for CNC machine programming. 3D CAD-CAM allows shops to efficiently manufacture complex geometry and handle harder jobs with much success.
NOTE: All of the information in this article is available as functionality in BobCAD-CAM Software. The Advanced Roughing, REST, High-Speed Adaptive Roughing and advanced Machine Simulation are available in the Mill 3 Axis PRO version of the software.
bobcad v32 cnc software
8 responses to “CAD-CAM Software for 2D and 3D CNC Machine Programming”
  1. dodiya haresh says:
    cad cam software install
  2. rajbeer Singh says:
    I want to learn cam programming
  3. shekhar says:
    i choose my lifes succes are here
    i already learn cnc vmv operating i want to do big and having own shop at pune
    so please help me to go through bob cad cam learning
    thank you
    dear
    shkhar
  4. civil engineer says:
    thank you very much for your informative article and more thanks for i get best idea read this article about .many more days i was searched this topics, finally i got it.
  5. amit says:
    thank for sharing us… best information for blog. it is useful tips and idea for post.
  6. M Narasimha eao says:
    Programming learning
