Bcc.ArcFrom3Entities
Bcc.ArcFrom3Entities({entity1}, {entity2}, {entity3})
This function is utilized to form an arc which is tangent to 3 entities.
  • entity1 - table providing the first entity definition
  • entity2 - table providing the second entity definition
  • entity3 - table providing the third entity definition
The supported entity types available as inputs are:
Return
Returns a table containing an arc definition in the ArcFromPoints format.
Examples
-- Create an arc which is tangent to 3 entities
function ArcFrom3Ents()
    --Define the entity colors to use
       inputGeoColor = "DarkGreen"
       outputGeoColor = "Black"
       --Create the input entities
       ent1 = {Type="Point", Point={-30,0,0}, Color=inputGeoColor}
       ent2 = {Type="Line", StartPoint={30,0,0}, EndPoint={0,30,0}, Color=inputGeoColor}
       ent3 = {Type="Line", StartPoint={30,0,0}, EndPoint={0,-30,0}, Color=inputGeoColor}
       --Generate the arc from the 3 entities
       arc = Bcc.ArcFrom3Entities(ent1, ent2, ent3)
       --Set the arc color to the output color
       arc.Color = outputGeoColor
       -- Create the geometry that was used as inputs as well as the arc
       Bcc.StartUndo("Arc From 3 Entities")
       Bcc.AddEntities({Type="ContourList", List = {ent1,ent2,ent3,arc}})
       Bcc.EndUndo()
end
