Bcc.GetActiveDocumentName
Bcc.GetActiveDocumentName()
Bcc.GetActiveDocumentName(Option)
This function is utilized to get the current document name and/or file path
The primary input of this function can be either a string or an integer which both have the same meanings.
String Option
  • FullPath
  • NoPathHasExt
  • NoPathNoExt
  • HasPathNoExt
  • ExtOnly
Integer Option
  • 1 - "Full Path"
  • 2 - "NoPathHasExt"
  • 3 - "NoPathNoExt"
  • 4 - "HasPathNoExt"
  • 5 - "ExtOnly"
Return
With no input parameters this function will return the string containing the full path with file extension
Based on the input option parameter the return will give all cases of either the full file path, just the file name with extension, just the name, etc.
Examples
String Input Parameter
For these examples let's assume your document is saved to the C: drive and is named BobCAD1.bbcd
-- Get the full file path with document name and extension
-- OUTPUT: C:\BobCAD1.bbcd
Bcc.ShowMessageBox(Bcc.GetActiveDocumentName())
Bcc.ShowMessageBox(Bcc.GetActiveDocumentName("FullPath"))
-- Get just the document name and extension
-- OUTPUT: BobCAD1.bbcd
Bcc.ShowMessageBox(Bcc.GetActiveDocumentName("NoPathHasExt"))
-- Get the document name with no extension
-- OUTPUT: BobCAD1
Bcc.ShowMessageBox(Bcc.GetActiveDocumentName("NoPathNoExt"))
Bcc.ShowMessageBox(Bcc.GetActiveDocumentName("HasPathNoExt" ))
-- Get the extension of the file
-- OUTPUT: .bbcd
Bcc.ShowMessageBox(Bcc.GetActiveDocumentName("ExtOnly"))
Integer Input Parameter
The following examples will generate the same output as above but instead you can use the integer values
Bcc.ShowMessageBox(Bcc.GetActiveDocumentName(1))
Bcc.ShowMessageBox(Bcc.GetActiveDocumentName(2))
-- OUTPUT: BobCAD1
Bcc.ShowMessageBox(Bcc.GetActiveDocumentName(3))
Bcc.ShowMessageBox(Bcc.GetActiveDocumentName(4))
-- OUTPUT: .bbcd
Bcc.ShowMessageBox(Bcc.GetActiveDocumentName(5))
