Bcc.GetRotationMatrixXYZ(xAngleDegree, yAngleDegree, zAngleDegree)
Provides the 4x4 rotation matrix when rotating around X, Y, Z axes with degree values.
- xAngleDegree - double value representing the degrees to rotate around the X axis
- yAngleDegree - double value representing the degrees to rotate around the Y axis
- zAngleDegree - double value representing the degrees to rotate around the Z axis
Return
Returns a 4x4 matrix containing the rotations specified in degrees.
The format of the return is the following assuming you have returned to a variable named matrix:
matrix[1] = {1,0,0,0}
matrix[2] = {0,1,0,0}
matrix[3] = {0,0,1,0}
matrix[4] = {0,0,0,1}
Examples
The following example shows the result of calculating a rotation which is 45 degrees around X
-- Get the matrix for rotating 45 degrees around X
matrix = Bcc.GetRotationMatrixXYZ(45,0,0)
-- Value to build the string for display
temp = ""
-- Iterate through the table and sub tables to display the values
for k,v in ipairs(matrix) do
if type(v) == "table" then
for kk, vv in ipairs(v) do
temp = temp..vv..", "
end
else
temp = temp..v..", "
end
temp = temp.."\n"
end
-- Display a message box of the resulting matrix
Bcc.ShowMessageBox(temp)
