TextBox_DoubleNoUnit
A text field containing a double value that will not utilize the BobCAD unit.  Common for angles or other no unit converted values.
Keys
  • Value – Default double value when dialog is launched, also the key for the value in returned result table
Return
["ControlID"]["Value"] - key value of the return table from the dialog which contains the contents of the text box.
data = { ControlID="StartAngle", ControlType="TextBox_DoubleNoUnit", Value=1.0*25.4 }
The return data can be accessed from (assuming the dialog return variable is named retTable ):
       retTable["StartAngle"]["Value"] = the data entered by the user
