Bcc.ChamferBetween2Entities
Bcc.ChamferBetween2Entities({ChamferMethod, parameter1, parameter2, {Entity1}, {Entity2}})
This function is utilized create a chamfer between 2 entities.
The primary input of this function is a Table which can include the following keys:
  • ChamferMethod - integer value representing the chamfer creation method:
    • 0: Angle and First Distance
    • 1: Angle and Second Distance
    • 2: First Distance and Second Distance
  • parameter1 and parameter2 - this are the input angles and distances, and the meaning of the double value specified here changes depending on the ChamferMethod specified:
    • ChamferMethod=0 - parameter1 is the angle and parameter2 is the first distance
    • ChamferMethod=1 - parameter1 is the angle and parameter2 is the second distance
    • ChamferMethod=2 - parameter1 is the first distance and parameter2 is the second distance
  • Entity1 - table containing the first entity definition
  • Entity2 - table containing the second entity definition
Return
Returns a ContourChain with second entity as the chamfer line if success, otherwise the result will be nil
Examples
-- Create 2 line entities
line1 = { EntityType="Line", StartPoint={-15,-25,0}, EndPoint={15,-25,0}}
line2 = { EntityType="Line", StartPoint={ 25,-15,0}, EndPoint={25, 15,0}}
-- Define the chamfer method (could typically come from a dialog option)
method=0
-- Define the distances and/or angle that will be used for the chamfer
FirstDistance=10
SecondDistance=15
Angle=45
-- Check the method type and create the chamfer getting the new resulting chain back
if(method == 0)        then
       retList = Bcc.ChamferBetween2Entities(method,Angle,FirstDistance,line1,line2)
elseif method == 1 then
       retList = Bcc.ChamferBetween2Entities(method,Angle,SecondDistance,line1,line2)
else
       retList = Bcc.ChamferBetween2Entities(method,FirstDistance,SecondDistance,line1,line2)
end
