Bcc.CloseActiveDocument()
Bcc.CloseActiveDocument(Option)
This function is utilized to close the active document in the BobCAD-CAM software.
- If no input is provided, the document will be saved in it's current state and closed
String Option - Option - string value of the possible options below:
- "UserChoice" - prior to closing the document, the user will be presented with a save as dialog to give opportunity to name the file
- "AutoSave" - saves the document and then closes
- "AutoNotSave" - close the document without saving
Integer Option
- Option - integer value of the possible options below:
- 1 - "UserChoice"
- 2 - "AutoSave"
- 3 - "AutoNotSave"
Examples
-- Save and close the active document
-- Present a save dialog and close the active document
Bcc.CloseActiveDocument("UserChoice")
Bcc.CloseActiveDocument("AutoSave")
-- Close the active document without saving
Bcc.CloseActiveDocument("AutoNotSave")
Bcc.CloseActiveDocument(1)
Bcc.CloseActiveDocument(2)
Bcc.CloseActiveDocument(3)
