Bcc.GenChainListFromContourList({ContourList})
This function can be utilized to generate a ContourChain from a set of connected entities that are in any random order.
The primary input of this function is a Table which can include the following keys:
- ContourList – a table defining a ContourList of entities that a chain or chains can be created from.
Return
Returns an array of ContourChain lists containing the resulting ordered chain(s)
>= { ContourChain, ContourChain, ..., ContourChain}
Examples
-- Define a 25 x 25 square
pnt1 = { -25,-25, 0}
pnt2 = { 25,-25, 0}
pnt3 = { 25, 25, 0}
pnt4 = { -25, 25, 0}
-- Define a 50 x 50 square
pnt5 = { -50,-50, 0}
pnt6 = { 50,-50, 0}
pnt7 = { 50, 50, 0}
pnt8 = { -50, 50, 0}
- Define a matrix to shift by -100 in X
matShift = {{1,0,0,0},{0,1,0,0},{0,0,1,0}, {-100,0,0,1}}
--Build lines from the points of the 25x25 square shifted by the matrix
line1 = { EntityType = "Line", StartPoint = pnt1, EndPoint = pnt2, TransformMatrix = matShift}
line2 = { EntityType = "Line", StartPoint = pnt3, EndPoint = pnt4, TransformMatrix = matShift}
line3 = { EntityType = "Line", StartPoint = pnt2, EndPoint = pnt3, TransformMatrix = matShift}
line4 = { EntityType = "Line", StartPoint = pnt1, EndPoint = pnt4, TransformMatrix = matShift}
-- Build lines from the points of the 25x25 square not shifted
line5 = { EntityType = "Line", StartPoint = pnt1, EndPoint = pnt2}
line6 = { EntityType = "Line", StartPoint = pnt3, EndPoint = pnt4}
line7 = { EntityType = "Line", StartPoint = pnt2, EndPoint = pnt3}
line8 = { EntityType = "Line", StartPoint = pnt1, EndPoint = pnt4}
-- Build lines from the points of the 50x50 square
line9 = { EntityType = "Line", StartPoint = pnt6, EndPoint = pnt5}
line10 = { EntityType = "Line", StartPoint = pnt5, EndPoint = pnt8}
line11 = { EntityType = "Line", StartPoint = pnt6, EndPoint = pnt7}
line12 = { EntityType = "Line", StartPoint = pnt7, EndPoint = pnt8}
-- Define a contour list with the entities in a random order
retList = Bcc.GenChainListFromContourList({Type="ContourList", List={line1, line7, line2, line3, line5, line4, line8, line6, line9, line10, line11, line12}})
-- Perform an extrude using the newly form chain
ID5 = Bcc.CADOperation( {CmdName="Extrude Generated Chains", Type="Extrude", PositiveDistance=8, NegativeDistance=8, ChainList=retList, Color="#ff00b0f0"} )
