The Installed Lua Plug-ins dialog is utilized for managing any Lua plug-ins found in the LuaPlugins directory found in the BobCAD-CAM Data\BobCAD-CAM V## folder.
- Each plugin directory is listed in the dialog
- The plugin can be enabled or disabled by using the checkbox next to the plugin
- Each plugin can be Reloaded at run time, which is important for while you are creating the plug-in.
NOTE: Any time you modify the script file, the plug-in must be reloaded from this dialog if the BobCAD-CAM application is running.
This dialog can be accessed from the Backstage sidebar, or a command is available for you to add to the BobCAD-CAM ribbon bar.
