Post Variables Supported
Post Variables Supported by BcPost.GetValueOfPostVariable
The following list shows all the variables that are supported by BcPost.GetValueOfPostVariable() function as not all variables have been added as of BobCAD-CAM V35, BobCAM for SOLIDWORKS V10, BobCAM for Rhino V3:
x_f,
y_f,
z_f,
xr,
yr,
zr,
x_angle,
y_angle,
rotary_xy_angle,
xr_angle,
yr_angle,
rotary_xyr_angle,
prev_x,
prev_y,
prev_z,
xr_transform,
yr_transform,
zr_transform
euler_angle_zxz_intrinsic_1,
euler_angle_zxz_intrinsic_2,
euler_angle_zxz_intrinsic_3,
euler_angle_zxz_extrinsic_1,
euler_angle_zxz_extrinsic_2,
euler_angle_zxz_extrinsic_3,
euler_angle_xyx_intrinsic_1,
euler_angle_xyx_intrinsic_2,
euler_angle_xyx_intrinsic_3,
euler_angle_xyx_extrinsic_1,
euler_angle_xyx_extrinsic_2,
euler_angle_xyx_extrinsic_3,
euler_angle_yzy_intrinsic_1,
euler_angle_yzy_intrinsic_2,
euler_angle_yzy_intrinsic_3,
euler_angle_yzy_extrinsic_1,
euler_angle_yzy_extrinsic_2,
euler_angle_yzy_extrinsic_3,
euler_angle_zyz_intrinsic_1,
euler_angle_zyz_intrinsic_2,
euler_angle_zyz_intrinsic_3,
euler_angle_zyz_extrinsic_1,
euler_angle_zyz_extrinsic_2,
euler_angle_zyz_extrinsic_3,
euler_angle_xzx_intrinsic_1,
euler_angle_xzx_intrinsic_2,
euler_angle_xzx_intrinsic_3,
euler_angle_xzx_extrinsic_1,
euler_angle_xzx_extrinsic_2,
euler_angle_xzx_extrinsic_3,
euler_angle_yxy_intrinsic_1,
euler_angle_yxy_intrinsic_2,
euler_angle_yxy_intrinsic_3,
euler_angle_yxy_extrinsic_1,
euler_angle_yxy_extrinsic_2,
euler_angle_yxy_extrinsic_3,
rpy_angle_xyz_intrinsic_1,
rpy_angle_xyz_intrinsic_2,
rpy_angle_xyz_intrinsic_3,
rpy_angle_xyz_extrinsic_1,
rpy_angle_xyz_extrinsic_2,
rpy_angle_xyz_extrinsic_3,
rpy_angle_yzx_intrinsic_1,
rpy_angle_yzx_intrinsic_2,
rpy_angle_yzx_intrinsic_3,
rpy_angle_yzx_extrinsic_1,
rpy_angle_yzx_extrinsic_2,
rpy_angle_yzx_extrinsic_3,
rpy_angle_zxy_intrinsic_1,
rpy_angle_zxy_intrinsic_2,
rpy_angle_zxy_intrinsic_3,
rpy_angle_zxy_extrinsic_1,
rpy_angle_zxy_extrinsic_2,
rpy_angle_zxy_extrinsic_3,
rpy_angle_xzy_intrinsic_1,
rpy_angle_xzy_intrinsic_2,
rpy_angle_xzy_intrinsic_3,
rpy_angle_xzy_extrinsic_1,
rpy_angle_xzy_extrinsic_2,
rpy_angle_xzy_extrinsic_3,
rpy_angle_zyx_intrinsic_1,
rpy_angle_zyx_intrinsic_2,
rpy_angle_zyx_intrinsic_3,
rpy_angle_zyx_extrinsic_1,
rpy_angle_zyx_extrinsic_2,
rpy_angle_zyx_extrinsic_3,
rpy_angle_yxz_intrinsic_1,
rpy_angle_yxz_intrinsic_2,
rpy_angle_yxz_intrinsic_3,
rpy_angle_yxz_extrinsic_1,
rpy_angle_yxz_extrinsic_2,
rpy_angle_yxz_extrinsic_3,
transform_plane_origin_1,
transform_plane_origin_2,
transform_plane_origin_3,
transform_plane_dir_x_1,
transform_plane_dir_x_2,
transform_plane_dir_x_3,
transform_plane_dir_z_1,
transform_plane_dir_z_2,
transform_plane_dir_z_3,
transform_plane_pnt_2_1,
transform_plane_pnt_2_2,
transform_plane_pnt_2_3,
transform_plane_pnt_3_1,
transform_plane_pnt_3_2,
transform_plane_pnt_3_3,
transform_plane_orientation_x,
transform_plane_orientation_y,
transform_plane_orientation_z,
transform_plane_rot_angle_first,
transform_plane_rot_angle_second,
transform_plane_rot_angle_third,
transform_plane_projection_angle_x_along_y,
transform_plane_projection_angle_y_along_x,
transform_plane_projection_angle_along_new_z,
x_pos,
y_pos,
z_pos,
probe_angle,
probe_dist,
probe_angle_tol,
probe_experience,
probe_feedback,
probe_feature_tol,
probe_true_tol,
probe_overtravel,
probe_inc_distance,
probe_work_offset,
probe_tool_offset,
probe_upper_tol,
probe_null_band,
probe_print,
probe_b_dia,
probe_angle1,
probe_angle2,
probe_angle3,
probe_x_dist,
probe_y_dist,
probe_x_dist2,
probe_y_dist2,
x_length,
y_length,
5rect_face,
5rect_p2_p4_pos,
5rect_dist,
5rect_p1_p3_pos,
probe_surf_output,
probe_rotary,
x_dist,
y_dist,
probe_pcd,
probe_num_features,
z_pos_k,
probe_cts_tool_type,
probe_cts_tool_diameter,
probe_cts_tool_tol,
probe_cts_length_exper,
probe_cts_broken,
probe_cts_overtravel,
probe_cts_tool_offset,
probe_cts_tool_length,
probe_cts_offset_typeA,
probe_cts_diam_exper,
probe_cts_z_clearance,
probe_cts_z_measure,
probe_cts_inc_radial,
probe_cts_rapid_pos,
probe_cts_clearance,
probe_cts_thermal_type,
probe_cts_thermal_measure,
probe_cts_thermal_x_storage,
probe_cts_thermal_y_storage,
probe_cts_thermal_z_storage,
probe_cts_overtravel_radial,
probe_nts_tool_type,
probe_nts_tool_tol,
probe_nts_length_exper,
probe_nts_broken,
probe_nts_overtravel,
probe_nts_spindle_speed,
probe_nts_tool_offset,
probe_nts_stepover,
probe_nts_solid_tool,
probe_nts_cutter_edge,
probe_nts_diam_offset,
probe_nts_diam_tol,
probe_nts_step_dist,
probe_nts_diam_exper,
probe_nts_tool_diameter,
probe_nts_search_dist,
probe_nts_measure_z,
probe_nts_num_edges,
probe_nts_feed_rev,
probe_nts_runout_tol,
probe_nts_safety_z,
probe_nts_start_angle,
probe_nts_end_angle,
probe_nts_check_height,
probe_nts_linear_dist,
probe_nts_radial_dist,
probe_nts_work_offset,
probe_nts_tool_length,
probe_nts_corner_rad,
probe_nts_profile_rad,
probe_nts_num_touch,
probe_nts_radial_option,
initpos_nocomp_x,
initpos_nocomp_y,
initpos_nocomp_z,
initpos_nocomp_prot,
initpos_nocomp_srot,
initpos_nocomp_trot,
initpos_zcomp_x,
initpos_zcomp_y,
initpos_zcomp_z,
initpos_zcomp_prot,
initpos_zcomp_srot,
initpos_zcomp_trot,
initpos_hybridcomp_x,
initpos_hybridcomp_y,
initpos_hybridcomp_z,
initpos_hybridcomp_prot,
initpos_hybridcomp_srot,
initpos_hybridcomp_trot,
initpos_tcp_x,
initpos_tcp_y,
initpos_tcp_z,
initpos_tcp_prot,
initpos_tcp_srot,
initpos_tcp_trot,
initpos_origintracking_x,
initpos_origintracking_y,
initpos_origintracking_z,
initpos_origintracking_prot,
initpos_origintracking_srot,
initpos_origintracking_trot,
initpos_x,
initpos_y,
initpos_z,
initpos_prot,
initpos_srot,
initpos_trot,
