TextBox_String
A text field containing a string value
Keys
- Value – Default string value when dialog is launched, also the key for the value in returned result table
Return
["ControlID"]["Value"] - key value of the return table from the dialog which contains the string from the text box.
data = { ControlID="StartAngle", ControlType="TextBox_String", Value="Some Text" }
The return data can be accessed from (assuming the dialog return variable is named retTable ):
retTable["StartAngle"]["Value"] = the data entered by the user
