Bcc.GetRotationMatrixAlongAxis({vOrigin}, {vDirection}, AngleDegrees)
Provides the 4x4 rotation matrix when rotating around an arbitrary vector a certain number of degrees
- vOrigin – table defining the x,y,z position of the start of the rotation axis vector: vOrigin={x,y,z}
- vDirection – table defining the vector direction: vDirection={xDir,yDir,zDir}
- AngleDegrees – double value representing the number of degrees to rotate
Return
Returns a 4x4 matrix containing the rotations specified in degrees.
The format of the return is the following assuming you have returned to a variable named matrix:
matrix[1] = {1,0,0,0}
matrix[2] = {0,1,0,0}
matrix[3] = {0,0,1,0}
matrix[4] = {0,0,0,1}
Examples
The following example shows the result of calculating a rotation which is 45 degrees around X
-- Get the matrix for rotating 45 degrees around X
matrix = Bcc.GetRotationMatrixAlongAxis({0,0,0}, {1,0,0}, 45)
-- Value to build the string for display
temp = ""
-- Iterate through the table to display the values
for k,v in ipairs(matrix) do
if type(v) == "table" then
-- Iterate through the sub table containing the values
for kk, vv in ipairs(v) do
temp = temp..vv..", "
end
else
temp = temp..v..", "
end
temp = temp.."\n"
end
-- Display a message box of the resulting matrix
Bcc.ShowMessageBox(temp)
