Stitch Surfaces to Solid
This topic will explain the Stitch Surfaces to Solid function, and the options found in it. This topic will also provide quick steps on how to use it, and provide links to related topics.
The Stitch Surfaces to Solid
The Stitch Surfaces to Solid function combines separate surfaces or solids into a single entity. To perform the function, you select geometry, and press the Spacebar to accept the selections.
To open Stitch Surfaces to Solid:
In the Modify group of the Create 3D ribbon, click
Stitch Surfaces to Solid.
Selected Geometry
Quick Steps - Stitch Surfaces to Solid
- Open the function.
The Selected Geometry list automatically has focus. - Select the surfaces to be stitched together.
The surfaces are added to the Selected Geometry list. - Click OK.
A Stitch Surfaces to Solid feature is added to the CAD Tree. - Repeat as necessary.
- Click Cancel to close the function.
(Delete) - removes
the highlighted item from the Selected Geometry list.
(Delete All)
