Leads
Leads
This topic explains the Leads page found in the Groove Rough operation of the Lathe Wizard.
The Leads page
Lead-in
The Lead-in is an additional move prior to the initial cut into the material. The Lead-in allows you to specify how the cut is approached.
  • Parallel - creates a lead into the material that is parallel with the toolpath move it is preceding.
    • Length - defines the distance between the start of the lead-in, and the defined toolpath.
  • Perpendicular - is unavailable for the Groove Rough operation.
  • Horizontal - is unavailable for the Groove Rough operation.
  • Vertical - is unavailable for the Groove Rough operation.
  • Angle - is unavailable for the Groove Rough operation.
  • Custom - is unavailable for the Groove Rough operation.
Lead-out
The Lead-out is an additional move following the last cut in the material. The Lead-out allows you to specify how the tool exits the cut.
    • Length - defines the distance between the end of the defined toolpath, and the end of the lead-out.
After defining the leads for the last operation in the wizard, click Compute to close the wizard and create the toolpath. If you are in a Mill Turn job, click Next> > to go to the MDI page.
