Patterns and Parameters
This topic will explain the Patterns and Parameters page of the Lathe Groove Finish operation and all the options found in it. This topic will also provide a link to the next topic.
The Patterns and Parameters page
The Patterns and Parameters page allows you to control the cutting pattern and compensation, while also providing options to adjust the depth of cut, allowance, overlap on passes, corner type (rolling over corners or not), and trimming the toolpath to match the stock size and shape.
Patterns
Pattern
Will allow you to select between a one directional semifinish, or a semifinish that forces a downward cut.
Basic Finish
Force Down Cutting
Force Down Cutting with Overlap
Force Down Cutting - selecting this option will force the semifinish to be cut from each side of the groove one at a time, each in a downward direction, to the middle of the groove. Adding an overlap will set each pass to go past the center of the groove half the specified amount.
Overlap - sets the total distance between the two passes exits, not including any leads that are uses.
Basic Finish - sets the semifinish pass to one single direction.
Compensation
Each tool has a theoretical point placed on it as seen in red in the animation below. In the case of tools with a radius of any size, this point is not actually on the tool, but on the horizontal and vertical intersections of the radius. It is this point that the toolpath plots out.  When compensation is used, it is designed to place the actual tool and not just its theoretical point on the geometry. This can be accomplished with System Compensation, Machine Compensation, or a combination of the two.
  • System Compensation
    • Off - the selected geometry is used as the program path; Machine Compensation should be used.
    • On with Collision Detection - the system compensates for the tool nose radius and the insert geometry and avoids any detected collisions.
    • On without Collision Detection - the system compensates for the tool nose radius and the insert geometry without checking for collisions.
System Compensation:
Theoretical Point
Off
  • Machine Compensation
    • Off - no compensation commands are output in the posted program.
    • Comp Left / G41 - outputs the left compensation command in the posted program.
    • Comp Right / G42 - outputs the right compensation command in the posted program.
The parameters section give you control over the allowances, if any, that are left on the selected geometry
Finish Allowance - will allow you to leave material on the workpiece to be handled by another finishing pass. Setting values for the Finish Allowance will leave the last pass of this operation offset from the selected geometry by the amount entered in the available Z and X boxes.
No Allowance
Finish Allowance
Chip Break
The option allows you to create minute retract moves, at user specified intervals, to aid in chip breaking.
Chip Break... - With this option cleared, the toolpath will not include chip break moves.
Chip Break... -  With this option selected, the toolpath will include chip break moves that can be modified in the Chip Break dialog. Click the Chip Break button to enter the dialog.
Chip Break... Chip Break...
This group allows you to determine how the intervals between retracts should be defined.
  • Length of cut - The retracts are determined by the amount of space between them.
  • Time - The retracts are determined by the amount of time between them.
  • Length of chip - The retracts are determined by the amount of material being removed between them.
Retract
  • Retract distance - sets the length of the retract move used to break chips.
Corner Type
Round - keeps the specified tool geometry in contact with the geometry at all times.
Sharp - allows the tool to move off the geometry in order to line up with the next move on the following entity. This method eliminates the rounding over of the tool.
Theoretical Point on Tool
Rounded Corner
Sharp Corner
Bounds
Trim to Stock -  With this option selected, the toolpath that extends beyond the Operation Stock will be trimmed away.
