Y Single Surface
The Y Single Surface Cycle
This topic will explain the Y Single Surface measure cycle, will describe how to access it, will explain the options found in it, and will explain how to use it with quick steps and an example.
This cycle measures a planar surface face which is parallel to the Y Axis. This cycle can utilize the following geometry inputs:
  • Line parallel to the X Axis.
  • Planar surface edge parallel to the X Axis.
  • Planar surface face whose normal is parallel to the Y Axis.
To access the Y Single Surface cycle:
  3. Click the Parameters tab.
Initial Position
  • Other Side - measures the opposing side of the surface from what is currently shown in the graphics area.
  • X - determines the end point for the cycle along the X-axis of the current Work Offset.
  • Y - determines the end point for the cycle along the Y-axis of the current Work Offset.
  • Update Work Offset
Quick Steps - Y Single Surface
  5. Click the Parameters tab.
Example - Y Single Surface
In this example we:
  • Select the Probe feature.
  • Select the cycle.
  • Utilize the Options page.
  • Backplot the result.
Part 2) Selecting the Probe
Part 4) Selecting the Cycle
The cycle can be selected with the drop down list under the Cycles section, but simply selecting the appropriate geometry will usually select the required cycle automatically. Since certain geometry could be applicable to several cycles, in some cases, the list will become much smaller. In this case however, there is only one cycle possible for the geometry we choose.
  1. Click the Parameters tab.
  2. Select a planar surface whose normal is parallel with Y, or the edge of that surface.
  1. In the Initial Position group, update the Y value by adding +0.5 to the end, and pressing Tab.
    The value and the toolpath update to put the initial position of the probe a half inch further forward in Y.
  2. In the Initial Position group, update the X value by adding -0.5 to the end, and pressing Tab.
    The value and the toolpath update to put the initial position of the probe a half inch further down in X.
Note: Since our toolpath is shown on the proper side of the surface, we have no need for the Other Side button in this group.
Part 6) Utilizing the Options page
  1. Click the Options tab.
Part 7) Backploting the result
    The Backplot dialog launches.
  2. Click Next to view the probe movements.
  3. Click Close.
