The CAD Tree
This topic will explain the CAD Tree, will explain where to access it, and will explain how to build on it, and the items in it. This topic will also provide links to related topics.
The CAD Tree
The CAD Tree in BobCAD-CAM is a solid history tree that allows you to edit, reorder, and suppress CAD features so you can update the CAD model at any time during the creation process or after. The CAD Tree contains features for each solid or surface body that you create, including all Solid and Surface functions, as well as any Utility functions that you use to modify solids. In addition to the feature, a solid item is added to the Solids folder, which provides selection tools for all solid bodies in the graphics area.
Wireframe geometry is not added to the CAD Tree, with one exception: the Shape Library. A feature is added to the CAD Tree for each shape that you create using the Shape Library.
To access the CAD Tree in BobCAD-CAM:
- Click in the
CAD
Tree Manager.
Beginning a CAD Tree
Features in the CAD Tree
The CAD Tree always contains the following two items.
BobCAD
File Name
Solids
After creating or modifying a solid or surface, a CAD feature is added to the tree. If a function creates a solid or surface entity, a corresponding Solid item is added to the Solids folder.
CAD Tree Feature Example
BobCAD
File Name
Solids
Solid 1
CAD Feature
Geometry
CAD Tree Shortcut Menus
Right-click the name of any CAD Tree item to access a shortcut menu with the options described in the following sections.
BobCAD
File Name
- Rebuild - recreates
all CAD features in the CAD Tree using the current order and status.
This option is used to update the CAD model after modifying the CAD
Tree, for example, after reordering features or modifying the wireframe
used to create a solid.
- Delete Tree History - eliminates all non-essential items from the CAD Tree.
- Optimize CAD Tree - combines all possible items in the CAD Tree.
- Collapse
Items - collapses the child items of the
CAD Tree.
This is the same as clicking the minus sign (
next to all child items of Milling Job. - Expand
Items - expands the child items of the
CAD Tree.
This is the same as clicking the plus sign (
Note: The only functions whose items in the CAD Tree can be combined are Translate, Rotate, Rotate 3D, and Delete. When combining items that have been renamed, the name of the most recent item is the name that will used. Also, keep in mind that not everything can be combined. Two Rotate functions with different rotation centers, for instance, can not be combined.
This item displays the file name as a reference to the CAD model.
The Solids Folder Menus
Note: NOTE: The Solids folder in the CAD Tree only displays an item for each visible solid entity that isn't suppressed. If you hide or suppress a solid entity, it is temporarily removed from the Solids folder.
Solids
Solid 1
Solids
- Select All -
selects all visible solid entities in the graphics area.
- Deselect All
- clears all solid selections in the graphics area.
- Refresh - updates
the Solids folder to correct any changes that are made.
Solid 1
- Select - selects
this solid entity in the graphics area.
- Deselect - clears
the selection of this entity in the graphics area.
- Destroy - completely deletes the item from the file. This option is only available for imported entities that are not used in the file. For example, if you import an entity and don't use it, you can remove the entity by clicking Destroy.
CAD Feature Edit Menus
The following context menu options are available for all CAD features that are added to the CAD Tree.
CAD Feature
Geometry
CAD Feature - Each CAD Feature will have a different icon, but regardless of the type of CAD feature, the following context menu will be the same:
- Edit - opens the function in the Data Entry Manager so you can edit the
parameters including the geometry selection.
- Rebuild
- rebuilds the feature after modifications are made, such as moving
or rotating the assigned geometry.
- Suppress/Unsuppress
- toggles the state of the CAD feature on the model. This turns the
feature on and off so you can modify the CAD model as needed. This
allows for design changes and provides a way to modify a model when
creating machining features.
- Rollback
- suppresses this feature and all features below it in the CAD Tree.
After using Rollback, the shortcut menu (of all suppressed features)
changes to include only Unrollback.
- Unrollback - unsuppresses the selected rollback feature and all features above it in the CAD Tree. This can be thought of as roll forward, as it unsuppresses all items previous to and including it.
- Delete Preceding Tree History - removes all items coming before this item in the CAD Tree except for Solid items.
- Rename
- enables the feature in the CAD Tree to be renamed by typing text.
Delete
- removes the CAD feature from the CAD Tree and deletes the output
geometry.
If the feature requires geometry selection, then the feature contains one or more Geometry items as follows.
Geometry
- Re/Select
- enables selection mode for you modify the currently assigned geometry.
- Reverse Direction - is used to swap the chain direction of the
selected geometry chain. This option is only available for geometry
items that use chain selection, for example, those for surface features.
- Remove - clears the assigned geometry from the CAD feature. If you do not assign new geometry, the feature will fail when rebuilt.
Using the CAD Tree
When using the CAD Tree, it is important to think about the actions you perform as an input and an output. You assign the input geometry that is used to create the output geometry. The output geometry may then be used as the input to another feature. The input and output of each action determines how you can modify the CAD Tree.
Editing CAD Features
When you edit a CAD feature, the model display in the graphics area returns to the same state as when you created the feature.
To edit a CAD feature:
- Right-click
the name of feature in the CAD Tree, and click Edit.
- Modify the Data Entry parameters, select the geometry if required, and click OK to update the feature.
The feature automatically rebuilds.
Rebuilding CAD Features
The are many situations when CAD features are automatically rebuilt, but there are some situation where you need to manually rebuild a feature. For example, after translating wireframe input geometry, you must rebuild the feature to recreate it in the new location.
To Rebuild a CAD feature:
- Right-click the feature name, and click Rebuild.
You may sometimes need to rebuild the entire model after making modifications.
Right-click the file name at the top of the CAD Tree, and click Rebuild.
Suppressing CAD Features
The Suppress option allows you to temporarily remove a feature from the CAD model to view the results without that feature. The following are a few important notes.
- When you Suppress a CAD feature, any feature below it in the CAD Tree that uses the output of the suppressed feature is also suppressed (automatically).
- The current suppression state of all features is used when rebuilding the CAD Tree.
- You can use Suppress to compare different designs or to allow for design changes.
- Suppress can be helpful when modifying the geometry to use for machining features.
To Suppress or Unsuppress a CAD feature:
- Right-click the feature name, and click Suppress/Unsuppress.
The model automatically rebuilds.
Rollback CAD Features
You can use the Rollback option to suppress the selected feature and all features below it in the CAD Tree. The CAD model in the graphics area returns to the state it was in prior to the rolled back feature. The shortcut menu for all features that were suppressed using Rollback changes to contain only one command: Unrollback. This option can be thought of as roll forward as it unsuppresses the selected feature and all features above it in the CAD Tree.
The following is an example usage of Rollback:
- Right-click
the feature name and click Rollback.
This feature and all features below it become suppressed. - You
can make changes to the feature previous to the rollback or add new features
as needed.
- If
you want to unsuppress all rolled back features, right-click the last
rolled back feature in the CAD Tree and click Unrollback.
To unsuppress only the first rolled back feature, right-click the feature name and click Unrollback.
Tip: If you create a new feature and move it above the rollback, you may sometimes need to Re/Select the geometry for the rollback feature (or the feature after) in order to properly rebuild the CAD Tree. (This is necessary when you are changing the input and output order of the CAD Tree.)
- Rebuild features or the entire CAD Tree as needed.
Reordering CAD Features
You can click and drag to reorder the CAD features in the CAD Tree with the following important notes.
If a feature is not associated to another feature, meaning that its input does not come from or its output isn't used by another feature, you can move it to any location in the CAD Tree.
You cannot move a feature above another feature that was used to create it.
You can always reorder Extrude Boss, Extrude Cut, and Solid Boolean Add, Subtract, and Intersect.
You can remove the assigned geometry from an associated feature to allow it to be freely moved, but you must then assign new geometry to recreate the feature. (Right-click Geometry, click Remove, then right-click the feature name and click Rebuild so it displays as failed. You can then move it.)
To reorder a CAD feature:
- Click and drag (press and hold the mouse button) a feature in the CAD Tree and point to the feature name that is above the location that you want to place the feature you are moving, then release the mouse button.
The feature is placed below the feature you are pointing to when you release the mouse button.
CAD Feature Highlight
You can click the CAD feature items in the CAD Tree to display the selected item in the graphics area using the current Highlight color. This is provided as a way to confirm the feature result as well as any geometry assignments at that point in the design process.
Deleting Geometry
It is important to understand how deleting geometry is handled with the CAD Tree.
Note: If you delete a solid from the graphics area using the Delete key or the Delete option, found in the Edit group, of the Home ribbon, a Delete item is added to the CAD Tree. This removes the geometry from the graphics area, but it is retained in the Delete item. This allows you to modify or bring back the deleted item later if needed.
If you want to delete solid entities from the graphics area without completely removing them from the file, you can use the Delete key or Delete option, found in the Edit group, of the Home ribbon.
To Delete a solid feature and have it stored in the CAD Tree:
- Delete geometry using the Delete command found in the Edit group of the Home ribbon.
A Delete item is added to the CAD Tree, which saves the deleted geometry.
To completely remove solid geometry from the file, you should use the CAD feature shortcut menu Delete option. This action is retained in the Undo list, which is removed once you close the file.
To Delete a feature and not store it in the CAD Tree:
- In the CAD Tree, right-click the feature name, and click Delete.
Deleting or Modifying Wireframe Input
Wireframe entities are often used to create solid or surface features in BobCAD-CAM. It is important that you don't delete any wireframe geometry that is used to create a solid or surface, unless you are assigning new geometry. If you delete the wireframe input to a feature, that feature will fail when rebuilt, as the CAD Tree stores solid, but not wireframe entities.
It is also important to be aware of any modifications that you make the wireframe input entities. For example, if you rotate the wireframe input to a solid, when the CAD feature or CAD Tree is rebuilt, the solid updates to the new wireframe orientation.
Changing CAD Feature Input
When changing the assigned geometry to a CAD feature, there are two methods that can be used. You can either Edit the feature to recreate it, or you can Re/Select the geometry and rebuild the feature. The result is the same, only the process is different.
After editing the input to a CAD feature, you may need to reassign the geometry. For example, if you delete wireframe entities and then replace them with new entities, you need to reassign the geometry to the feature.
To update modified input:
- Below
the feature name, right-click Geometry,
and click Re/Select.
- Update
the geometry selection as needed and confirm the selections.
There are some times that changing the input geometry requires you to edit the feature and reassign the geometry.
To edit a feature and its input:
- Right-click
- Confirm
or update the Data Entry parameters, select the geometry, and click OK to update the feature.
The feature automatically rebuilds. - If this change affects other features, right-click the file name at the top of the CAD Tree, and click Rebuild.
Failed Feature Indicator
When rebuilding the CAD Tree, if any feature cannot be properly rebuilt, for example, the input geometry was deleted, the feature displays the failed feature indicator as shown next.
CAD Feature
Geometry
When you see this indicator on a CAD feature, repair and/or reassign the geometry, and rebuild the feature. The indicator is removed when the feature is successfully rebuilt.
Organization
Tip: You may want to rename the CAD features to something that is appropriate for the model or that is easier for you to remember later. The default naming means that all similar features share the same name, so renaming can be very helpful in keeping your CAD Tree organized, especially when reordering features.
To Rename a feature:
- Right-click
the feature name, and click Rename.
You can also slowly click the feature name twice. - Type
the new name for the feature.
Press Enter or click anywhere else to save the new name.
CAD Tree Optimization
Tip: Using the CAD Tree can be a huge help when used properly. When used improperly it can turn an average sized file into a huge file. Utilize CAD Tree Optimization to reduce the size.
In general, functions should be used once and edited if the result need to be altered. In some cases, instead of editing a translation feature to the proper distance, more and more are created until the item is in the desired location. Since the CAD Tree is designed to track the history of the CAD model, all of those various positions are remembered. In order to assist with these situations, utilize the Optimize CAD Tree options:
- Right-click
BobCAD
File Name and select Optimize CAD Tree.
A dialog appears: Are you sure you want to Optimize CAD Tree History? This action can NOT be undone! - Click OK.
The CAD Tree is optimized. Any Delete, Translate, Rotate, or Rotate 3D functions that can be combined, are combined.
Delete Tree History
Tip: Using the CAD Tree can be a huge help when used properly. When used improperly it can turn an average sized file into a huge file. Utilize Delete Tree History to reduce the size.
The CAD Tree Optimization can be a huge help for people who utilize the functionality of the CAD Tree, but for those who do not, or in those instances where a model is completed and will not need to be modified, deleting the tree history is the best way to reduce the size of the file.
- Right-click
BobCAD
File Name and select Delete Tree History.
A dialog appears: Are you sure you want to delete CAD Tree History? This action can NOT be undone! - Click OK.
The CAD Tree history is removed. Only Solid items remain.
