Lathe Tap Parameters
This topic will explain the Parameters page of the Lathe Tap operation and all the options found in it. This topic will also provide a link to the next topic.
The Parameters page
The Parameters page of the Lathe Tap operation contains the variables needed for the feature.
Operation Parameters
- Use Cutting Conditions
this calculates the Overall Depth and Effective Depth for this operation.
Clear the check box to manually change the values that were automatically
calculated. - Effective Depth - the depth from the Top of Feature (face of the feature), excluding the tool tip.
- Overall Depth - total depth from the Top of Part (face of the feature), including the tool tip. This value is output in the posted NC program.
Cycle Type
- Single Depth -
outputs a G81.
- Peck
- outputs a G83. The First Peck (%) parameter (Cutting
Conditions dialog box) allows the system to automatically
apply a peck cycle based on material selected and the depth of the
hole. For example, if the value of First Peck (%) is set to 300 percent,
the system outputs a G81 until the depth of the hole is 3 times the
diameter of the drill. When the First Peck (%) is met, the system
outputs the G83 cycle.
